Home > Maintenance & Mods (L322) > How hard is changing the front lower rear arm? |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 488 |
Upper arm has the seperate ball joint lower arm is the one with the fitted one is correct i beleive.
16th Jan 2019 8:03am |
I did mine by chiselling it from the back and knocking the ball joint out the other side leaving the cassette part stuck. I then cut a groove in the inside face of the cassette through to the hub to give it a bit of room to move and smashed the living daylights out of it with a chisel and club hammer.
16th Jan 2019 8:21am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Thanks for the info Mark, those are good prices.
19th Jan 2019 7:16pm |
I tested mine with some lateral movement. Get a largish bar in between the upper and lower arms and pull down and see how much twist you have. A little bit is fine apparently a lot or if its easy the bush has too much play.
19th Jan 2019 8:43pm |
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 |
Ive done all the front end parts last week, upper and lower arms, ball joints and inner and outer track rods. Had previously done drop links. All parts fitted are bearmach which i ordered direct off there website and got free delivery. Approx £250 all in with 10% discount code. 2011 RR Autobiography 4.4 TDV8 |
19th Jan 2019 8:51pm |
Hi guys, just getting back on this - and re-reading comments. Mark, having re-read your comment above, and given I can't seem to get too much movement I am unsure as to what I should do. Tried using the wheel to generate movement, nothing really noticeable. kbald am trying to visualise your technique ^^ when you say lateral you mean left and right I guess. I think I need to get a bar in between the bush end and maybe the anti-rill bar? As you say Mark, that is a bush that seems to need a lot of play just due to it's hollow kind of design. i.e. it's not a solid rubber bush. Be good to know how much play would be acceptable. Any thoughts? Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
8th Mar 2019 9:49pm |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 |
The control arms are under pressure so you wont be able to diagnose it whilst on the car.. I tried everything and even tried a garage who said the play was normal. However when there is movement at both (the ball joint and bush) ends this is where you get typical (suspension parts worn) symptoms.
8th Mar 2019 10:14pm |
hi scot, thing is this arm has one bush, no ball joint.
8th Mar 2019 11:08pm |
also I've got no noise that's why I'm not 100% convinced on this...
8th Mar 2019 11:27pm |
Trust me.. you would be better of changing the whole arm.
8th Mar 2019 11:29pm |
so arm + cassette you are saying?
8th Mar 2019 11:33pm |
Check my post on the 1st page. Get a butane torch from Toolstation or Screwfix.. not expensive. Current:
8th Mar 2019 11:39pm |
ok a butuane torch I can do!
8th Mar 2019 11:46pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 835 |
It was upper/lower control arm plus ball joint day today on my car i decided to let my mate john do it for me and glad i did it was a pig of a job also while he had the hub off he replaced the outer cv boot and dropped in new brake pads.
9th Mar 2019 12:26am |
