Home > Technical (L405) > Overrevving ‘run a way’ TDV8 then engine died |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
I’m glad I ventured into the L405 section. It’s been an education. Well done Graeme. I’ve seen another vid of a D4 also with a runaway motor. ______________________________
12th Dec 2018 12:25pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2308 |
Here's one being fitted to my son's D4. |
12th Dec 2018 8:20pm |
Richardince Member Since: 14 Oct 2018 Location: Suffolk Posts: 39 |
Good news in that the engine has run today. However not running correctly due to blocked DPF and cat system in the exhaust system which is probably due to running on oil? Suspect this is going to go into week 10 now. |
12th Dec 2018 8:40pm |
Triarii Member Since: 10 Feb 2015 Location: Wess Vinglun Posts: 184 |
Late to this but my Disco2 failed like this. Porous engine block - if you got beyond 70k miles you didn't have it. Drank its own oil, engine ran away, clouds of white smoke. Kaput. Got it fixed then got a D3....then an L322, then the L405. 17 MY Corris Grey 4.4 VAB
12th Dec 2018 10:16pm |
Week 11 tomorrow. Cats and DPF filter now replaced but new engine not running very well. Now looks like a faulty injector so waiting for parts again! Suspect it’s going to be 2019 before I get it back now. |
21st Dec 2018 8:17pm |
Now in week 14 and had the car back briefly last week. Car vibrates at 1200-1400 revs at constant speed. If change down a gear this vibration stops. Any Ideas? |
16th Jan 2019 11:51am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2516 |
Set fire to the dealership? |
16th Jan 2019 12:31pm |
Engine mounts? Torque converter? |
16th Jan 2019 12:41pm |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 843 |
Hi all
18th Jan 2019 5:48pm |
Finally after 17 weeks (tomorrow) got the car back again and the new engine now appears to be working correctly.
8th Feb 2019 9:36pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Wow Richard, that's over four months.
8th Feb 2019 9:40pm |
mrtidy Member Since: 31 Aug 2015 Location: Stockport Posts: 211 |
good to here Richard. I did wonder how things were going but 17 weeks is a bit of a wait. 2009 Vogue SE Zermatt silver |
8th Feb 2019 10:07pm |
Didn’t the new motor include injectors or was it a bare block? ______________________________
9th Feb 2019 4:57am |
No, injectors not supplied with bare engine which in the end were all either faulty or out of spec when tested. Tips damaged running on engine oil. There are apparently no Land Rober tests to test injectors on the engine.
9th Feb 2019 5:43pm |
