Home > Technical (L322) > Heeeeeeelp !
Page 2 of 3 <123>
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
yes and no , ive had to clear faults , do the steering reset too but the toggle doesnt respond and its indicating usually at the normal road height , though I noted the self level button also lights which only usually happens if I have the trailor on , if I go onto calibrate the system nothing happens , I get the feeling im just not doing things in the right order or ????? im going to try my Delphi kit on the X5 setting to see if it will also do what the snap on did today , ive got an L200 clutch to do tomorrow so hope I get time after that , good job I bought a lil van just before xmas otherwise I'd av been up sheet creek Rolling Eyes
Post #501838 16th Jan 2019 9:28pm
holidaychicken
when you clear the faults do you hear the pump start to run ?
The light on the toggle switch when you push the button in is an inhibit switch which stops the suspension adjusting and also when the trailer is connected.
The light also indicates a soft fault in the system that it will try to correct itself as opposed to a hard fault when all the lights are off and the only way to sort it is with diagnostics
Post #501842 16th Jan 2019 9:47pm
bembo449
I do if I do the steering reset , yes
if I operate the toggle the normal road height stays lit and depending on which one ive gone for , it just flashes , I will have a look and see if the Delphi will work or borrow the modus again , bit pushed for time at the mo though Rolling Eyes
Post #501845 16th Jan 2019 9:51pm
tony66
Scotland 2005 Range Rover HSE Td6 Tonga Green
transport
check its not stuck on transport mode or something daft like that-also that the height sensor actuator arms have not inverted themselves giving weird readings
Post #501846 16th Jan 2019 10:05pm
bembo449
when I got it 2 years ago its was stuck in transport mode , ive checked all the arms are moving well etc pal so that rules them out but how do it get it out of / check wether it is stuck ??
Post #501847 16th Jan 2019 10:07pm
tony66
transport
it all depends if you are using the solus pro,bmw inpa etc as to where you find it on the menu tbh
i have sold my solus now and use delphi on most cars,and have bought a hawkeye pro-but still finding my way around that
you will just need to check all the pages-it was pretty clear in the bmw section of the snap on iirc
Post #501851 16th Jan 2019 10:57pm
bembo449
Ok so was that on the bmw X5 on solus pal ? Cant remember seeing it in the LR program , i have INPA so can look on there if neccessary
Cheers
Simon
Post #501853 16th Jan 2019 11:05pm
bembo449
Another update , using delphi on the bmw X5 programme , i have the options of activating all suspension bits and turning off transport mode so that is good news , however the compressor isnt kicking in , the fuse in the boot had blown , i replaced but still nothing , if i activate say , the front strut i can hear faint clicks n wurs so its looking like ive goosed the compressor while testing it yesterday , opinions guys ??
Post #501917 17th Jan 2019 6:39pm
tony66
transport
so was it stuck in transport mode?
Post #501918 17th Jan 2019 6:54pm
bembo449
I cant say for sure with the compressor not working , couple of can codes to delete but they never returned , as i said above , activate any part and i can hear things working so that suggests that its not but i did start by removing transport mode
Post #501919 17th Jan 2019 7:07pm
tony66
air
should be simply sorted once you fix the compressor-they seem a bit fragile if you ask them to do too much graft...
Post #501962 18th Jan 2019 1:18am
bembo449
What can i do to be 100% sure the comp is goosed ??
Post #501971 18th Jan 2019 9:41am
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
I had this exact same problem. Dont panic, nothing is broken at all.
The solution I followed was to re-enable the EAS using an iid tool. Then manually inflate all the bags using the iid tool. When the car is somewhere near the right high you can stop and start again. Everything will kick back in as normal
Where are you located?
Post #501972 18th Jan 2019 9:49am
bembo449
As i said earlier pal , the comp isnt responding to any activation i try so i need to check the comp to be sure before looking at other possible causes , i have bo faukt codes either
Im in north lincolnshire pal
Post #501975 18th Jan 2019 9:53am
Try powering the compressor directly from a battery .
Post #501977 18th Jan 2019 11:19am
Page 2 of 3 <123>
