![]() | Home > Technical (L322) > Locked Door Drama |
nar53 Member Since: 05 Nov 2015 Location: Le Mans Posts: 120 ![]() ![]() ![]() |
OK So I went out to the Fatty at half Six this morning to start the old girl up. Opened the door got myself in & started her up no problem. The dash was saying -4c & I wished I'd put it under cover. Next - Start up the wife's car. Turn to get out & the door wont open (the Fatties door) Hmm, must've hit the lock button. Hit the lock button again - Nothing. Turn on the interior lights to see whats going on. Lock the doors, unlock the doors no luck the drivers door stays firmly shut. opened the window leaned out & locked & unlocked with the key - No luck. Lean across & try passenger door which thankfully opens no problem. By now times going by, I've got to drop our son off for his school bus & get to the Doctors so time to abandon the fatty which is running fine but wont open.
Did it freeze up (doors seals) while you were sat in it ? .
Hi Joe
Hi Dolphinboy.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
had a similar thing on my 12 plate last year when it was cold, but the lock would stick open, ie open door, go to close door and it wouldnt latch.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
Opening the door would allow the ingress of cold air to the lock. John 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
I'll give it a good blast of Silicone in the morning. |
paul70 Member Since: 06 Mar 2018 Location: North Yorkshire Posts: 101 ![]() ![]() ![]() |
EXACTLY the same happened to me on Wednesday morning!
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3259 ![]() ![]() ![]() |
into the interior of the lock (where the "hook" is that goes over the protruding restrainer (hope that makes sense! Will try and get a pic later)
Thanks, that makes sense. Will get some spray this afternoon and will take a look in the morning as the Mrs is in the RR today. |
crabbtrux Member Since: 10 May 2017 Location: Devon Posts: 2 ![]() ![]() ![]() |
Hi all.
