Home > Technical (L322) > Locked Door Drama
nar53
France 2002 Range Rover Vogue Td6 Giverny Green
Locked Door Drama
OK So I went out to the Fatty at half Six this morning to start the old girl up. Opened the door got myself in & started her up no problem. The dash was saying -4c & I wished I'd put it under cover. Next - Start up the wife's car. Turn to get out & the door wont open (the Fatties door) Hmm, must've hit the lock button. Hit the lock button again - Nothing. Turn on the interior lights to see whats going on. Lock the doors, unlock the doors no luck the drivers door stays firmly shut. opened the window leaned out & locked & unlocked with the key - No luck. Lean across & try passenger door which thankfully opens no problem. By now times going by, I've got to drop our son off for his school bus & get to the Doctors so time to abandon the fatty which is running fine but wont open.
Now for the interesting bit, I'm not very mobile, knackered knees, knackered hips, dodgy ticker & a bit porky (read a lot porky)
Half stand up, twist around & try to get my leg over Very Happy the console. My foot is stuck between the seat & the steering wheel. I can't move & my dodgy ticker is thumping!
Managed to sit down again. Chill Chill Chill. OK Put the seat back as far as possible & try again. Woo Hoo I made it. Only damage is the microphone knocked off the dash.
Locked the Fatty & took the spare car. Small, Cold, Bouncy but the doors opened. So I did my stuff, came home, made a cuppa & read the wikki. It seems I need a piece of bent wire & to remove a rubber plug. Followed by a bit of luck.
So I armed myself with tools & wire & head outside. Now the sun is shining, first time for weeks & its +4c which is good.
Before I start lets try the door! it works! I get inside & start the car open & close the door & it works - every time. But will it last?
So I've pulled out the bung made a piece of bent wire which will live in the passenger door pocket & we'll see how it goes. In the meantime Fingers crossed.
Anything else I can do?
Post #501984 18th Jan 2019 12:12pm
Did it freeze up (doors seals) while you were sat in it ? .
Post #501989 18th Jan 2019 1:15pm
nar53
Hi Joe
The door seals were all frozen but I could open them. The drivers door had definitely been locked either by me or by itself. I just hope it doesn't happen again.
Post #501991 18th Jan 2019 1:32pm
Dolphinboy
The inner mechanism of the door lock will have frozen adn the electrics don't have enough power to activate the release. You need to shoot some silicon into the lock. Thumbs Up
Post #501993 18th Jan 2019 1:47pm
nar53
Hi Dolphinboy.
I was thinking something on those lines. But its odd it unlocked OK in the first place & then promptly locked itself once the door was shut again.
Post #502004 18th Jan 2019 4:09pm
had a similar thing on my 12 plate last year when it was cold, but the lock would stick open, ie open door, go to close door and it wouldnt latch.
Good spray of silicone spray into where the bung is has sorted it for the rest of the year. Thumbs Up probably do it again before it gets really cold! There is nothing that can't be fixed with a hammer😜😜
Post #502013 18th Jan 2019 5:15pm
Weegie
nar53 wrote:
Hi Dolphinboy.
Opening the door would allow the ingress of cold air to the lock. John
GAP iiD BT-Sold
Post #502019 18th Jan 2019 5:58pm
nar53
I'll give it a good blast of Silicone in the morning.
Post #502047 18th Jan 2019 10:53pm
nar53
Weegie wrote:
nar53 wrote:
Hi Dolphinboy.
Post #502048 18th Jan 2019 10:53pm
paul70
EXACTLY the same happened to me on Wednesday morning!
Opened up started car, started up and put heated screens and heaters on.
Went and started wifes 208 and did the same.
After hers was defrosted off she went and I couldn't get back in my car.
Needed to get to work so had to climb in via passenger side.
Once at work (aprox. 5 mile drive) worked fine and has done since.
Will get some silicone spray today exactly where does it need spraying?
Paul.
Post #502739 25th Jan 2019 9:05am
Dolphinboy
into the interior of the lock (where the "hook" is that goes over the protruding restrainer (hope that makes sense! Will try and get a pic later)
Also where the rubber bung is.
Post #502750 25th Jan 2019 11:39am
paul70
Thanks, that makes sense. Will get some spray this afternoon and will take a look in the morning as the Mrs is in the RR today.
Post #502753 25th Jan 2019 12:11pm
crabbtrux
United Kingdom 2005 Range Rover Vogue Td6 Barolo Black
Hi all.
Just reading this 'cure', how do you open a locked door to fix anything? It's not mentioned above. My passenger door won't open, even if you manage to grab the lock button with thin noses and pull it up, it just springs back down again. Inner door handle obviously isn't doing anythi g, I'm not that daft! Car is a 2005, last of the td6's. Mrs is getting proper grumpy about sitting in the back, and she knows I have a cordless angle grinder!
Post #572061 7th Nov 2020 12:45pm
