Home > Technical (L322) > Battery Check ?
Rob99
Battery Check ?
Well, it had to happen some time!
First cold snap of the year night before last (although only down to -6) and yesterday evening the Westie wouldn't start. Unlike other cars I have had, I presume the clever fattie doesn't even try to start if it thinks there isn't enough juice in the battery. Hence everything else seemed to be working.
Didn't get a chance to investigate until this morning but when I went out it started first time.......go figure!!
Battery now on the CTEK for the day but how do i check whether the battery is on its way out? It was new when i had the Westie 2.5 yrs ago (LR Exide one)
Cheers 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #502393 22nd Jan 2019 11:52am
could it be the starter motor problem Rob?
Post #502403 22nd Jan 2019 12:54pm
rjff
Rob
Could it be the battery failing?
I had some problems with funny faults coming up and a non-start or two. Booked it into Halfords (wash my mouth out) for their free check and they said battery not good from their tester. Long story short, took it back to dealer who fitted a new battery, original only just over 12 months old, fitted when we bought the car and failing. Not bad service as car not on extended warranty but battery warranty honoured.
Seems so far FFaultless. Cheers
Richard
Gap IIDBT
Post #502406 22nd Jan 2019 1:10pm
Balloonengineer
If the battery is fairly flat, but when you hook it up to a charger it doesn't take much amps, then its knackered. I have a desulphating machine, and to be honest, when a battery is gone, its only a short term remedy.
A problem is most of the modern chargers are plug and go, with an led light to say its charging, but doesn't say how much, and without an ammeter.
If its flat, the ammeter should be showing 5-8 or more amps, if its flat and its only taking 2 or 3 then its gone.
Sadly with the cost of raw materials and everything being built down to a price, batteries, even branded names just don't last any more.
On the flip side, you could argue, by a cheap one and replace it every couple of years, and you will probably be better off.
Best wishes
Glen Previously......
Series 1 80, Series 3 88, Turbo 90, 300tdi 90, 110's with 200, 300, TD5
TD5 Disco, Disco 3, 200Tdi Disco - probably the best vehicle Landrover ever made,
Now 3x FFRR, some would say I should have learned by now......
Post #502411 22nd Jan 2019 1:27pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
if it's a westminster then i think it will be an AGM battery so you will need an AGM (=expensive) replacement. charge properly
according to other threads on here, you can fit a 'normal' battery if you tell the computer via IID tool.
hopefully someone more knowledgable that I will come along and clarify
Post #502421 22nd Jan 2019 2:35pm
DrRob
From my list of personally saved links
https://www.fullfatrr.com/forum/topic43662...11+battery
https://www.fullfatrr.com/forum/topic49156...3dabc1d84b
https://advancedbatterysupplies.co.uk/product/varta-g14/ Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #502422 22nd Jan 2019 2:52pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Ah Batteries!
Can't help with the test -- short of putting it on a battery tester -- but to clarify, you *should* have an AGM battery -- when they are changed the car needs to be 'told' typically IID can do this.
I'm trying (by default, stupidity, or simply lack of knowledge) a 'normal' non AGM battery in my 4.4 TDV8, I can confirm that only an 019 battery will fit and not an 020 that 'can' be fitted to earlier models.
Hope some of the helps Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #502423 22nd Jan 2019 2:53pm
Rob99
Oh, is there a common starter motor problem that I haven't heard about? Shocked Shocked 2021 D350 Fifty Edition - Carpathian Grey
Post #502424 22nd Jan 2019 2:56pm
there is Rob...starts with pressing the button and getting a click and nothing , then next time its ok but eventually the frequency of non starts gets more and more...
Post #502426 22nd Jan 2019 3:07pm
Rob99
Thanks Stan, a little worrying now i don't have a warranty...... Big Cry
I'll see how things go over the next few weeks 2021 D350 Fifty Edition - Carpathian Grey
Post #502428 22nd Jan 2019 3:20pm
if you still have the OE battery on then it could be that....i had to replace my OE one last year..
Post #502432 22nd Jan 2019 3:48pm
Baltic Blue
+1,
So did I. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #502434 22nd Jan 2019 3:51pm
kooky_guy
+1 me too! 2010 4.4 TDV8 Vogue SE
Post #502494 23rd Jan 2019 7:45am
paul70
Fitted new one on mine a short while ago and no problems since.
Also has stopped an array of minor faults being logged in the engine management module which must have been related to low battery.
Most frustrating thing was I had been let down a number of times since leaving the car standing for periods of over a week but on each occasion RAC connected jump leads and let the battery charge then tested and each time couldn't definitely confirm there was anything wrong with the battery but were able to confirm the battery drain when stood wasn't excessive.
My battery was JLR / Varta branded so I'm guessing was original so if that was the case I suppose is pretty good for a 2011!
Replaced as per recommendation from Baltic Blue (Mike) - see thread. Some other helpful info on the thread also.
Regards
Paul
https://www.fullfatrr.com/forum/topic49156.html
Post #502738 25th Jan 2019 7:55am
