![]() | Home > Technical (L322) > Battery Check ? |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1473 ![]() ![]() |
Well, it had to happen some time!
could it be the starter motor problem Rob? |
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 180 ![]() ![]() ![]() |
If the battery is fairly flat, but when you hook it up to a charger it doesn't take much amps, then its knackered. I have a desulphating machine, and to be honest, when a battery is gone, its only a short term remedy.
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
if it's a westminster then i think it will be an AGM battery so you will need an AGM (=expensive) replacement. charge properly
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
From my list of personally saved links
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Ah Batteries!
Oh, is there a common starter motor problem that I haven't heard about? ![]() ![]() 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
there is Rob...starts with pressing the button and getting a click and nothing , then next time its ok but eventually the frequency of non starts gets more and more... |
Thanks Stan, a little worrying now i don't have a warranty...... |
if you still have the OE battery on then it could be that....i had to replace my OE one last year.. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3851 ![]() ![]() ![]() |
+1,
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
+1 me too! 2010 4.4 TDV8 Vogue SE |
paul70 Member Since: 06 Mar 2018 Location: North Yorkshire Posts: 101 ![]() ![]() ![]() |
Fitted new one on mine a short while ago and no problems since.
