Home > Technical (L322) > snow mode, front diff unlocked
used the FF in the snow today and switched on the 'snow/gravel' mode and the dash showed the front diff unlocked....
my question to those that know, what benefit does having that diff unlocked give whilst driving in the snow ..
Post #503547 1st Feb 2019 11:59am
mpirie
I noticed the same when I used snow and gravel too when I went "exploring" a couple days ago, or "dicking around" as my wife calls it!
I had the chance to raise the suspension and use low range because of the depth and softness of the snow.
Maybe the front diff only locks on low range?
I'd be interested to hear from more experienced members too.
Mike
Post #503555 1st Feb 2019 12:18pm
Baltic Blue
Snow, ?
23c and sunny in Tenerife. Rolling with laughter Rolling with laughter
Post #503556 1st Feb 2019 12:20pm
you're missing all the fun we're having here Mike.. Laughing
Post #503557 1st Feb 2019 12:26pm
DrRob
My understanding is it auto locks when the RR decides it needs to due to wheel slip/spin etc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #503558 1st Feb 2019 12:26pm
Baltic Blue
That is my understanding as well.
It only locks when drive is lost to one wheel.
Post #503559 1st Feb 2019 12:29pm
GraemeS
Australia
I guess that you're referring to the centre diff.
Post #503561 1st Feb 2019 12:43pm
Mikey
Wasn't aware of any L322 fitted with a locking front diff...
Rear was an option, and they all have the centre diff lock, but front... Confused
Post #503562 1st Feb 2019 12:43pm
Mark.abersoch
United Kingdom 2010 Range Rover Vogue SE TDV8 Bonatti Grey
If the front diff locks you'll lose steering! Shocked
I'm not sure they have a locking diff in the front do they? Surprised 2009 TDV8 Vogue SE - Bonatti Grey
Post #503565 1st Feb 2019 12:47pm
CS
There is no 'benefit' as such, the car is just showing you what it is doing, so the car is driving fine in the standard setting despite the snow. If traction is being lost then the padlock symbol changes to closed to show the differential being locked. You'd feel it too. Only Range Rovers since 1988
Post #503568 1st Feb 2019 1:20pm
TomCobbly
It's all great stuff but absolutely useless if a load of jacknifed cars and lorries in front and behind you are blocking the road Rolling Eyes 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #503573 1st Feb 2019 1:59pm
GraemeS
Australia
The display doesn't tell the whole story. If you monitor the locking % using an IIDtool then you will see that the centre and rear e-diff, if fitted, are often pre-loaded to varying degrees even when no special program is in use yet not loaded high enough to trigger the locked symbol. The locked symbol only shows once a threshold has been reached and when shown, doesn't mean that the diff is effectively locked solid. As I've churned through mud, once the e-diff lock symbol shows, the locking % can reduce to well below the threshold yet the lock symbol stays on, only going off if the diff remains below the threshold for an extended time.
Post #503607 1st Feb 2019 8:57pm
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
As stated previously with a front diff locked you get real lousy steering , when competing (in 90) I usually run centre and rear locked and leave the front free unless I know I'm going to need it , it's then ulocked as soon as possible as you've got Censored all turning ability with everything locked up , (many years ago on a Bulldog someone I know ended up upside down in a ditch from locking his front diff and going straight on ).
Post #504084 5th Feb 2019 9:45pm
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
matthews
Bulldog is an event from the past, I am Keith, used to help Brian run the events. I had a Grey 90 V8 back then 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #504117 6th Feb 2019 11:16am
Norm
Canada 2008 Range Rover HSE 4.4 V8 Alaska White
Torsen diff locks can be used on steering axles without steering lose and are fully automatic.
Post #504227 7th Feb 2019 12:53am
