Home > In Car Electronics (L322) > Bluetooth upgrade |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
There's a write up in the wiki on here detailing how to do it. |
25th Nov 2017 3:04pm |
philcorsa Member Since: 11 Apr 2016 Location: vienne Posts: 43 |
i've seen it but sorry i don't understand anything, may be i'm stupid ! RR L322 4.4 TDV8 Vogue
25th Nov 2017 3:17pm |
well first many thanks to Adrian Wiggins for is wonderful help.
2nd Dec 2017 5:32pm |
gizze Member Since: 06 Jun 2016 Location: Norfolk Posts: 162 |
In case anyone else sees this who has the connector like above.
23rd Dec 2017 12:56pm |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 666 |
I was lucky enough to spot a New Old Stock late Bluetooth Module on ebay just after Christmas (Part No. AH42 10F845 AA ) for less than many were trying to sell S/H units & have just installed it using the Wiki link as a guide.
11th Jan 2018 8:52pm |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 |
just installed the later module on my rr ,thanks wiggs for the info ,i did mine a little different i got a new unit and i also got the multi plug with the 2 wires coming out of it ,i got a 2pin lead male and female spiced into the loom and soldered the 2 pin female length into the loom and the male onto the tails coming out of the multi plug i can now unplug it and keep the multi plug that goes into the module or i can use the old nokia if i need to swap new module to another rr |
15th Jul 2018 12:31pm |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 701 |
whare is this part located RR 2005 4.4 petrol
16th Jul 2018 2:45pm |
It's in the boot, left hand side rear , behind the pull out panel where the Sat Nav & Audio amp is located Paul,
16th Jul 2018 4:42pm |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 |
Does the later module have expanded functionality? I see most ads post the module with "Central locking unit" as description. 2007 L322 3.6 TDV8 Stornoway |
2nd Nov 2018 10:39pm |
The later part (part no. as above) gives you access to your mobile phones phonebook via Bluetooth & will show all phone nos if you have multiple nos for the same person.
2nd Nov 2018 11:26pm |
Thanks Paul,
3rd Nov 2018 5:44am |
jncunliffe Member Since: 01 Mar 2013 Location: Dorset Posts: 8 |
Has anyone tried to upgrade from the old Nokia style BT unit, mines on a L322 MY07, to the Jaguar version of the 'new' BT module, part number 7G9N-10D893-AG....? It looks identical to the LR part but looks can be deceiving...!
1st Feb 2019 3:11pm |
petercole237292 Member Since: 04 Sep 2020 Location: west sussex Posts: 1 |
4th Sep 2020 2:30pm |
