Home > Maintenance & Mods (L322) > Servicing rear brake calipers 2011 model
Baltic Blue
I have been searching for a thread that might help me strip down, clean and free up my rear brake calipers, but not found a good β€œhow to β€œ guide.
I have done the front pads etc with no problems, but would like to do the rears once the weather improves.
Any β€œtips” appreciated.
Post #503674 2nd Feb 2019 3:43pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Just contemplating the same thing.
I have a sticking rear caliper aswell. cleaned both calipers up approx 18 months ago, when I fitted new pads & discs.
Reading through posts & other people having issues with Non OE calipers. I'm thinking about getting a second hand unit & rebuilding it, then like you fit it when the weather improves.
Anyone else fully rebuilt their rear calipers or just purchased new ones. Whistle
Post #503676 2nd Feb 2019 3:59pm
Just so your aware, both cars above have completely different types of rear callipers...
Late cars have much less issues with rear callipers than the 02-10MY cars...
Highroller, i would simply replace yours as rebuilt rear callipers are cheaper than the time and effort it costs to rebuild yours! And the parts maybe from an unknown quality Thumbs Up
Post #503677 2nd Feb 2019 4:06pm
Baltic Blue
Thanks Craig Thumbs Up
Mine is really preventive maintenance , to clean off any road salt/ grit etc. and hopefully grease up the sliding pins, but I have worries about affecting the EPB , which seems tricky ?
I have got new pads ready to fit, but when I checked them last month they are still only half worn.
Post #503681 2nd Feb 2019 4:15pm
Highroller
Cheers Craig, Probably best to obtain a new caliper. Considering the effort / cleaning I went through last time.
Post #503687 2nd Feb 2019 4:27pm
nino_nino
Mike, if you are changing only rear pads and not rear disks you will not be touching EPB. changed mine rear pads this spring and it is straightforward job. Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #503781 3rd Feb 2019 11:19am
Baltic Blue
Thanks Nino,
Did you clean and grease the sliding pins at the same time ?
That is my plan.
Cheers
Post #503787 3rd Feb 2019 12:17pm
nino_nino
yes I have. used Textar brake lube. can't remember when squeezing pistons in if it is necessary to twist them at the same time. 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #503796 3rd Feb 2019 12:45pm
I think the pistons just press in.
I need to strip mine too as they have developed a bit of a squeak. There is nothing that can't be fixed with a hammer😜😜
Post #503812 3rd Feb 2019 4:16pm
kooky_guy
I've just had to replace both of my rears. One of them seized completely (bit irritating as I had just had the disks and pads replaced and they were apparently fine then as 'they know what to look out for') and I had the other one replaced as a precaution.
As far as I know, they did all the typical preventative maintenance when they did the disks and yet this one still seized 2 months later. 2010 4.4 TDV8 Vogue SE
Post #503874 4th Feb 2019 9:39am
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
best wishes Fella
Post #503879 4th Feb 2019 11:05am
Baltic Blue
Thanks,
It will be my first job when I get home from my holiday enjoying a bit of winter sunshine in Tenerife.
Looks pretty straightforward, πŸ‘πŸ‘
Post #503887 4th Feb 2019 12:07pm
EmiratesA380
Baltic Blue
Enjoy the Holiday fella - who did you fly with - hope it was no easy jet !
someone told me last week they got a flight abroad and only paid Β£20 return !!!! - hell that's about 3 seconds worth of fuel on the 380 at start up
Post #503891 4th Feb 2019 12:19pm
One thing missed on that video would be to pull the sliders out of the calliper bracket clean them & refit using the appropriate grease... I would also grease the disc securing bolt... And finally, if your going to that much trouble, why not paint the outside of the disc? He's clearly painted the bells, why not the outer edge?
Just my 2 peneth Whistle Thumbs Up
Post #503892 4th Feb 2019 12:24pm
Baltic Blue
It was Thomas Cook flight this year, but we usually use Jet2 .
We were very lucky to get away on time because Manchester was closed for a few hours the following day whilst they cleared the runway and de-iced the planes.
Beautiful here at the moment though, 24c and unusually, virtually no wind.😎😎
Cheers Emirates πŸ‘
Post #503893 4th Feb 2019 12:28pm
