Home > Maintenance & Mods (L322) > Servicing rear brake calipers 2011 model
Baltic Blue
It is just the sort of preventative maintenance job that I really enjoy doing.
Not too complicated and I can sit down and take my time., knowing that it will help keep my car in tip top condition. Thumbs Up
Post #503895 4th Feb 2019 12:39pm
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Baltic Blue wrote:
It was Thomas Cook flight this year, but we usually use Jet2 .
We were very lucky to get away on time because Manchester was closed for a few hours the following day whilst they cleared the runway and de-iced the planes.
Beautiful here at the moment though, 24c and unusually, virtually no wind.😎😎
Cheers Emirates 👍
Mike.
Hey Mikie
ENJOY That Holiday Fella
Post #503905 4th Feb 2019 1:56pm
Also missing (from the video) was the process to release, and keep released, the EPB.
The 07-10 manual says something about needing to "drive the parking brake to the mounting position".
What is the safe process for the DIYer with an iiDTool ? .
Post #503913 4th Feb 2019 2:48pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Just two things on the video. Need to use axle stands for safety & I wouldn't use a sharp object on the caliper seals, as this could tear a seal Whistle
Nice to hear that you having good weather in the canaries. We usually travel out Nov / Dec & were considering Jan / Feb, but thought they would be a little chilly (24 C is very pleasant).
At least the break gives you plenty of time to read up on this. Thumbs Up
Post #503916 4th Feb 2019 3:00pm
EmiratesA380
[quote="Joe90"]Also missing (from the video) was the process to release, and keep released, the EPB.
T
WELL DONE FELLA from air crew - nice to see you took the time to post something of interest for all of us to see
Post #503921 4th Feb 2019 3:33pm
Weegie
" it clearly shows he looks after his FF " But not his skin and hands. Shocked John
GAP iiD BT-Sold
Post #503927 4th Feb 2019 4:40pm
Shaun
England 2011 Range Rover Vogue 4.4 V8 Orkney Grey
Had a sticking rear n/s caliper and rebuilt last weekend. Ordered a new piston and seal kit from Brakeparts.co.uk, good quality and reasonably priced. Had to force the piston out with servo assistance as it seemed to very tight. The piston had rust inside the caliper, so i'm thinking the brake fluid was not changed as the main dealer stamps suggest. Rear discs not in the best of condition and have been on the list for replacement. However, after refit and test drive i now have a shiny n/s disc, the caliper can't have been exerting that much force on the disc. Although not binding i suspect the o/s requires a rebuild also. Sorry i didn't take pictures, but there was snow on the ground and i had cold hands. Will take pictures of the o/s when i do that one.
Post #504289 7th Feb 2019 1:23pm
