![]() | Home > Technical (L322) > 2012 4.4 TDV8 Engine Bay |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3885
First thing to check are the 4 short rubber hose .
| 1427.rangerover Member Since: 29 Jan 2019 Location: North Lincs Posts: 3
Hi all. Complete story so far on restricted performance RR 2011 4.4ltr.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
If it were me, I’d take it to another independent specialist for an opinion.
Checked all previous recommendations ie hoses etc. As commented previously all were replaced. Checked MAP sensor and found to be very badly contaminated and blocked. Will replace sensor unit and clean inside {dougnut} air intake, when I obtain parts.
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2777
The sounds as though the secondary inlet isolation valve is sticking. An improved version of the valve was fitted from early in 2012. |
The valve gives an error code when it fails, but sorry I don’t know it.
| All times are GMT |
