Home > Technical (L322) > 2012 4.4 TDV8 Engine Bay
Baltic Blue
First thing to check are the 4 short rubber hose .
Remove the plastic engine cover (just pulls up )
Then look for any splits in the short hoses.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #503267 29th Jan 2019 9:49pm
GGDR
Quote:
have been told requires new turbo.
It's highly likely to be the hoses as Baltic Blue says if so, a massive watch out to whoever told you this....
And welcome btw! Loads of help here. Post some pics of your car too. Thumbs Up
. Cheers, Greg
Post #503281 29th Jan 2019 11:43pm
1427.rangerover
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Hi all. Complete story so far on restricted performance RR 2011 4.4ltr.
2017 Restricted performance. Found split in joint inlet manifold L/H. Local dealership replaced L/H inlet manifold and also four inlet hoses with upgraded hoses modification. All seals as required replaced. Vehicle runs ok. After 3 months use approx ( only used to tow caravan) 1000mls approx use. Restricted performance whilst towing caravan. Recovery attended vehicle . Diagnostic showed fault on vacuum valve lower front L/H side. Cancelled code vehicle run ok no further problem. Fault restricted performance started again after a further 2500mls. Returned vehicle to dealership cleared fault codes. Unable to find a problem. Each time restricted performance fault appears , after switching off engine wait 10min fault disappears and engine runs ok. Took vehicle to independant L/R specialist, found sticking R/H turbo actuator also carried out smoke test. Advise possible turbo fault. req replacement. I still believe fault lies with vaccumm valve operation. Fault only appears if you drive at a constant speed for a duration of time then increase speed slightly to overtake a vehicle . RESTRICTED PERFORMANCE. Does anyone know what is the flow of air from from both air filters to both turbo's. What valves and monitering equipment and how they operate.
Best rgds John
Post #504079 5th Feb 2019 8:56pm
DrRob
If it were me, I’d take it to another independent specialist for an opinion.
Have you checked the hoses as per Baltic Blues post above? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #504082 5th Feb 2019 9:29pm
1427.rangerover
Post #505707 19th Feb 2019 8:30pm
1427.rangerover
Checked all previous recommendations ie hoses etc. As commented previously all were replaced. Checked MAP sensor and found to be very badly contaminated and blocked. Will replace sensor unit and clean inside {dougnut} air intake, when I obtain parts.
Has anyone replaced the starter motor on this engine before and if so what is the procedure for removing the said item looks rather tight up there. rgds John
Post #505708 19th Feb 2019 8:38pm
GraemeS
Australia
Re: Turbo issue with 4.4ltr diesel
1427.rangerover wrote:
Car runs fine until extra speed required then goes into restricted performance. Engine can be reved up and down whilst vehicle is statioinary without any fault.
The sounds as though the secondary inlet isolation valve is sticking. An improved version of the valve was fitted from early in 2012.
Post #505751 20th Feb 2019 2:18am
Baltic Blue
The valve gives an error code when it fails, but sorry I don’t know it.
Good news is it’s an easy replacement job. (They quote 1.8 hours)
Mine was swapped under warranty.
Post #505768 20th Feb 2019 9:40am
