Home > Maintenance & Mods (L322) > Washer Jets
Simon123
Wales 2010 Range Rover Autobiography TDV8 Santorini Black
Washer Jets
Hi,
My windscreen washer jets have packed up after a little bit of snow and ice. Do they have to be replaced or can they be unblocked??? If so would be grateful for an idiots guide on how to remove them for replacement/ repair!! See there's an electrical connector and rubber pipe to remove, any other info would be much appreciated.
Cheers
Post #504258 7th Feb 2019 10:55am
Are they not just frozen sir? Don't know how warm the weather has got down your neck of the woods? Seems strange they have both blocked! Remove the tubing going to your bonnet then press wash and see if you have flow first Thumbs Up
Post #504265 7th Feb 2019 11:12am
Simon123
Thanks for reply. They were working normally until last week until there was a bitof snow on bonnet. I've disconnected rubber tubing and pump is working and there is water flow.
Have disconnected electric cable and pipe from unit does anybody know correct procedure for removing wiper jet???????????!
Post #504284 7th Feb 2019 1:05pm
mpirie
Each washer jet has a lip at the front (windscreen) and a squeezy tang at the rear (bonnet front).
You squeeze the tang while pushing the jet up out of it's slot in the bonnet.
But.....beware, you need to take the hose and electrical connector off first because the hole isn't big enough to get the connected jet out and you risk snapping off the hose connector, necessitating replacement.
Try a small pin as your jets may be blocked by grit. Disconnect the hose and blow compressed air into the jet from the outside/top, blowing any crap out of the hose connector.
Mike
Post #504328 7th Feb 2019 5:35pm
Simon123
Hi Mike,
Thanks for that , will have another go tomorrow as rain has stopped play !!
Post #504345 7th Feb 2019 6:29pm
JCW
Having had the same problem after freezing, once removed I've disassenbled the jet unit, inside is a small spring and a small red rubber grommet that appeared to have been dislodged from its normal position and blocked any fluid flowing through to the jets.
I suspect its a one way valve type arrangement but I ended up just picking the rubber part out completely and the jets returned to what seemed like normal operation.
Post #504356 7th Feb 2019 7:04pm
^ Spot on. Thumbs Up
It is indeed an non return valve to stop the washer liquid draining back into the washer bottle.
Had exactly the same problem on both jets a few years ago and as above disassembled the jets, removed the gubins and all has worked perfectly since. I half expected the liquid to drain back but surprisingly the jets work instantly when required.
Not worth buying new jets.
Post #504380 7th Feb 2019 9:20pm
Simon123
Thanks for advice, will try the suggested remedies before I order new jets
Post #504412 8th Feb 2019 10:42am
