Home > General > Fixing up a tatty L322 - is it doable? |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 |
I just did this, bought a "cheap" L322 with a few niggles, but at this point I'm quite sure I've spent a lot more money than I would've on a better car. The small things on these are not cheap, and on slightly neglected cars, much of the fun (but not essential) bits have failed, and not been repaired. Usually stuff you won't notice right away. On mine I've fixed the Bluetooth, GPS antenna, venture cam, Outer tie rods, TPMS (still working on that one), DVD-changer, FBH, replaced both power side steps, rusted tailgate, loose headlight washer nozzles, faulty PDC-sensor, remanufactured transmission, and today I found 2-3ml of oil in the right side intercooler hose.. So, turbo is on the menu. There's also a few bushes on the rear suspension that doesn't look great (The biggest ones, naturally).
10th Feb 2019 4:30pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16165 |
All SC's got the venture cam up until hmmmmm 2009 i think? certainly through 2007MY...
10th Feb 2019 4:59pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3684 |
2006 MY onwards from Vogue upwards got the venture cam - not sure when they stopped. All the SC should therefore have it from launch. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
10th Feb 2019 5:26pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3191 |
My MY2005 Td6 had a venture cam. My MY2008 Tdv8 doesn't. John
10th Feb 2019 6:27pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 835 |
I bought a 4.4 v8 petrol with a garage diagnosed head gasket failure minimum new engine required most likley........i bought it..... nothing wrong with it when i got it home and compression tested it, full service and im 3k miles into very nice ownership goes well with the fleet |
10th Feb 2019 6:53pm |
LivingtheDream Member Since: 06 Feb 2019 Location: Baldock Posts: 35 |
Thanks all - Sounds like owning a TVR - stuff needs doing and it costs, or takes time, or both!
10th Feb 2019 10:17pm |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 508 |
Do you know the battery is okay in the key that doesn't work? Some of them {mine for example} have a rechargeable battery that is charged in use. Only ever use one key and the other one gradually discharges. I'm not sure whether it would still disable the immobiliser with a dead battery? 2016 Skoda Octavia VRS Estate
11th Feb 2019 9:53am |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
You can definitely save money getting a brilliantly maintained immaculate car with ONE big fault (e.g. needs engine or transmission). On an L322, you can probably source one 2nd hand and, if you’re handy and don’t have to pay labour, you can certainly come out ahead.
12th Feb 2019 12:00am |
Nin Member Since: 17 Feb 2019 Location: Abingdon Posts: 4 |
I guess it’s the same for cars and bikes - I bought an accident damaged BMW GS to rebuild, a pretty straightforward job really but inevitably ended up spending waaaay more than I would have if I’d just bought a good ‘un.
17th Feb 2019 9:31pm |
