Home > In Car Electronics (L322) > Replacing the head unit on the cheap |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34910 |
easily replaced with an android unit...do a search and read this from our wiki,
9th Feb 2019 7:33pm |
Danbhardy Member Since: 10 Nov 2018 Location: Chorley Posts: 44 |
Yeah have read that. Makes no sense to my simple mind!
9th Feb 2019 7:53pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Depends what system is already in there and whether it has built in amps or if the car has individual amplifiers ie logic 7. If it's a head unit with built in amplifiers then a simple adaptor lead is required. If not then you will need to bypass the amps.
10th Feb 2019 10:01am |
There’s a dash adapter I can get.
10th Feb 2019 10:03am |
Not seen the dash adaptors before but if it works it should be simple enough. I don't think the hse will have individual amps.
10th Feb 2019 10:08am |
Yeah, seen the video for that
10th Feb 2019 10:15am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
That thread says the pix have been reinstated but they don't appear. Ron B. VK2OTC 2004 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
10th Feb 2019 11:00am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7628 |
Might be easier to get another hse unit from a breakers and do like for like swap.
10th Feb 2019 11:02am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
I had a double din unit fitted in my old hse. Depending on the size of the unit, a fair amount of the plastic behind the dash has to be trimmed . The android unit appears to be an easier fit because it’s a better shape to the rear. One thing we did find out is that if you have a cente dash speaker, there will be a small amp in the left cubby in the boot. IIRC you need a trim piece from an e39 5 series to fill the hole . Not too daunting if you are handy with some basic tools, or find s9meone local to fire one in. I ran about for ages with a Bluetooth speaker in mine when the stereo packed up! |
10th Feb 2019 12:28pm |
This might give you an idea of what you can get?
10th Feb 2019 2:05pm |
I don’t know as I don’t know much about the stereo.
11th Feb 2019 8:55pm |
