![]() | Home > Technical (L322) > 5.0 Supercharged Engine Rattle |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7964 ![]() ![]() ![]() |
I don’t have one, but aren’t there known issues with timing chains and guides? 2011 Range Rover Vogue SE 4.4 TDV8
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 ![]() ![]() |
I have just listened to your video , the noise you are hearing is the vanes of the supercharger compressor bouncing off each other (roots style) due to bearing failure.
Bit of info here
tuki Member Since: 28 Mar 2018 Location: Istanbul Posts: 22 ![]() ![]() ![]() |
Unnecessary quote removed
That link is for the whole nose assembly, you dont need that , you just need the FULL repair kit as that has the bearings for the rotors as well |
Clabs Member Since: 08 Mar 2017 Location: Watford, Herts Posts: 125 ![]() ![]() |
Hi Tuki
hey folks, here is an update on the situation |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 709 ![]() ![]() ![]() |
Well done in identifying & resolving your issue.
