Home > eBay & Bargain Spots > nextbase dab and BT @£25 delivered |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
9th Feb 2019 3:06pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
Ooh, been looking for a dab receiver for the bm, thanks Stan |
9th Feb 2019 7:12pm |
Springer Member Since: 15 Nov 2017 Location: Merseyside Posts: 104 |
Hi has any one fitted one of these is how pictures would be great
12th Feb 2019 6:41pm |
found this using our search function,
12th Feb 2019 7:54pm |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 |
Added photos |
14th Feb 2019 7:29pm |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 509 |
Apologies for being a bit dense, but does this only require a power lead, and it plays music via FM? |
14th Feb 2019 7:50pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Play's via the Aux in socket Current: 2011 FFRR Vogue SE 4.4 TDV8
14th Feb 2019 7:54pm |
Thanks |
14th Feb 2019 7:56pm |
Ballogie Member Since: 25 Jan 2019 Location: Scotland Posts: 15 |
yup - has an FM transmitter - tune your FM radio to it - FM transmitters are so much better than they used to be
14th Feb 2019 8:01pm |
stu_007 Member Since: 25 Jun 2016 Location: Cardiff Posts: 177 |
Thanks Ballogie; I’ve ordered one, as mine doesn’t have aux in. "YYS" G4 FFRR
14th Feb 2019 9:01pm |
You can use either mines on aux in easy to fit just been for a run great signal £25 well spent |
14th Feb 2019 9:40pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 785 |
Ive plugged an iphone and an ipod in to the aux in the rear but found the volume at the head unit needed to be turned right up to hear either ? |
15th Feb 2019 12:49pm |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 252 |
@DaveK: Yes this is normal with FFRR AUX In (at least in mine). I use DAB+ unit over FM transmitter as shown above. Works fine and volume level and sound quality is good.
15th Feb 2019 1:11pm |
The volume on this one is fine as loud as you want and adjustment works thro your steering wheel when used thro the aux input |
15th Feb 2019 4:39pm |
