Home > Maintenance & Mods (L322) > Cattle Grid shudder at 50MPH to 55MPH
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys started experiencing the cattle grid shudder only at 50 to 55MPH and only when taking foot off accelerator at 50MPH then easing it back on slowly do I feel the shudder I do not get the shudder if I give it heavier acceleration from 50MPH. I have had tyres checked twice for balancing and they are fine. I had my gearbox and torque convertor done at 127000 and I'm on 156000 at the minute so surely not the torque convertor at fault or is kit! Any ideas.
Cheers
J Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #505229 15th Feb 2019 3:10pm
Could possibly be a sticking brake or brake calliper, was on mine. Have you checked the wheels for heat after a run?
Post #505236 15th Feb 2019 3:59pm
jaysta10k
Hi I had a sticking break calliper last year which caused smoking and a full on wobble steering due to the heat warping the disc at anything over 30MPH. I don't seem to think to could be a calliper problem as this problem only occurs at 50 to 55 MPH and there a lot of people saying online that it points to the Torque Convertor but I will deffo have all the callipers checked to rule iyt out.
Cheers
Previous Cars
BMW M3 Carbon Black
Post #505238 15th Feb 2019 4:06pm
It could well be the torque converter but brake callipers are a lot cheaper. Thumbs Up Very Happy
Post #505240 15th Feb 2019 4:17pm
PaulTyrer
United Kingdom 2003 Range Rover Vogue 4.4 V8 Epsom Green
Way back i used to have a Ford Granada 2.8i Ghia estate and had a similar type of vibration. It turned out to be a split in the propshaft 'spider' joint where the rubber joint had split between the bolts.
Post #505249 15th Feb 2019 5:34pm
gavinn
Probably the torque converter, had mine done a few months ago with exactly the same symptom.
Also had a slight variation between the engine revs increasing around 200rpm and then dropping 200rpm with no gear change at around 40mph, turned out it was an issue with the lock up clutch in the torque converter ...
Converter changed all went away
Post #506433 26th Feb 2019 9:58am
Weegie
As Nicedayforit says you can quickly check for sticking caliper slide pin by the temperature at the wheel. The sticking one will be much hotter. John
GAP iiD BT
Post #506441 26th Feb 2019 10:52am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
jaysta10k, did you get to the bottom of this? 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #514183 4th May 2019 8:48am
jaysta10k
Hi Still not resolved this issue had front breaks checked again even changed pads had callipers cleaned up etc...I have changed one injector which was number 6 giving an abnormal read no difference though. What is strange is that when engine is cold I do not get the shudder at 55MPH at slight acceleration. I also get shudder when I'm giving it a bit of revs in reverse.I am going to change Injector 1 as this is giving off strange reads to see if this cures it. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #514760 9th May 2019 11:22am
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
Watching this with interest, as I have the same issue albeit at slightly higher speed (65-70). Next step for me was also to have the callipers checked, but I'm going to mention the T/C and the prop joint for them to look at.
Post #514808 9th May 2019 7:19pm
jaysta10k
Hi Cappo do you also get a slight feathering in RPM at about 1500 to 2000 and a vibration shuddering when you reverse only when applying acceleration in reverse though. My gear changes are smooth no slipping and no hesitation up hills etc and the car has no loss of power. It’s doing my head in now I’m hoping it’s an injector issue I will soon know when it’s In for MOT next week they going to change injector 1. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #514814 9th May 2019 7:39pm
Cappo
I'll pop out and check those things tomorrow Jaysta - not as I remember, but tbh I don't drive the car that often, once or twice a fortnight generally Sad
Post #514815 9th May 2019 7:44pm
jaysta10k
UPDATE this has been sorted finally it turned out to be a faulty injector Cylinder 1 so no more shudders in reverse or at 55MPH. But I still have a slight feather on my RPM Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Previous Cars
BMW M3 Carbon Black
Post #516286 23rd May 2019 9:00am
Cappo
Mine's in being investigated as we speak.... 5.0 S/C Autobiography
Defender 3.9i Auto, Aston Martin DB9, Fiat Coupe 20V Turbo Plus and seven, no eight, bikes!
Previously:
4.4 AJ V8 Vogue, RRC, 4.6 VSE P38, Disco V8, SIII V8 - there's a theme here! Plus multiple others, some of which were also V8s!
Post #516292 23rd May 2019 9:26am
Gary Williams
United Kingdom 2004 Range Rover Vogue Td6 Buckingham Blue
Hi,
I had that last week. I finally lost all drive. The transmission oil filter was clogged. New 6l of oil and one filter fixed it. However, if there is enough crap to block the filter, it is likely the clutches are on their way out so the oil change is likely to be a short term fix.
Regards
Gary
Post #516331 23rd May 2019 3:06pm
