![]() | Home > Wheels & Tyres > Replace 255/50/20's with 255/55/20's?? Any issues?? |
RaveRover Member Since: 14 Mar 2017 Location: Melbourne Posts: 36 ![]() ![]() ![]() |
I have recently fitted Nitto Terra Grappler G2's on my L322 275 55 20.. They equate to a touch under 32". I have to trim up the drivers side rear wheel well tub where the fuel filler goes down and have a look at the spot welded seam at the top of the wheel arch. Other than that they fit and look awesome. Big difference to the standard 265 50 20 roadies.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4342 ![]() ![]() ![]() |
Anybody tried these?
Springer Member Since: 15 Nov 2017 Location: Merseyside Posts: 104 ![]() ![]() ![]() |
Hi I'm running 255-55-R20 on my td6 with no problems after running 285-35-22 the ride is much better my spare wheel is a 19 so fitted 255-60-19 which just fits in the spare tyre well with the lifter the floor is slightly proud |
Did you get the 55 to fit ok in the wheel well with a bit more air than 2 bar? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 341 ![]() ![]() |
Here's a good comparison
Look good. Did the 55 spare go into wheel well ok? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
255 55 20 General Grabber AT3 being fitted next week.... |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 235 ![]() ![]() ![]() |
Had AT3’s fitted on mine last year. Can’t fault them.
What size? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
255/55/20. As mentioned before the spare is a tad snug, had to deflate to about 18psi to get it in.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2743 ![]() ![]() |
I have 255/60R19 GG AT3 on D4 rims ready to go on when my current tyres wear down enough. They have a little more sidewall height and a higher load rating than 255/55R20 GG AT3 yet have the same OD. They fit in the spare wheel well at full pressure although mine's left side plastic has been trimmed to fit 275/55R20. |
![]() Does the floor still sit flat on top? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Yes the floor will sit flat. Bit of a wrestle to get the wheel in though. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35818 ![]() ![]() |
you dont have to struggle with a 55 in the spare.....use a space saver wheel or one of the original 50 profiles as a spare.... ... - .- -.
