Home > Wheels & Tyres > Replace 255/50/20's with 255/55/20's?? Any issues??
Page 4 of 6 <123456>
RaveRover
Australia 2005 Range Rover HSE 4.4 V8 Java Black
I have recently fitted Nitto Terra Grappler G2's on my L322 275 55 20.. They equate to a touch under 32". I have to trim up the drivers side rear wheel well tub where the fuel filler goes down and have a look at the spot welded seam at the top of the wheel arch. Other than that they fit and look awesome. Big difference to the standard 265 50 20 roadies.
Thanx Matt Once you've driven a Range Rover, everything else seems 2nd rate.. Eeeek I'm trapped for life.
1986 RRC Highline with offroad mods. Arctic Silver
2001 P38 HSE. Ardeness Green.
1995 RRC soft dash (beautiful car) Green.
2005 L322 HSE V8. - Current, most awesome car yet. And most expensive.
Post #494768 6th Nov 2018 8:56am
DrRob
Anybody tried these?
https://www.tyreleader.co.uk/car-tyres/gen...07h-829173 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #503695 2nd Feb 2019 4:10pm
Rob99
Do you have to tell your insurer if you're changing from 255/50 to 255/55 ?? 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #505250 15th Feb 2019 5:59pm
Springer
United Kingdom 2003 Range Rover Vogue Td6 Galway Green
Hi I'm running 255-55-R20 on my td6 with no problems after running 285-35-22 the ride is much better my spare wheel is a 19 so fitted 255-60-19 which just fits in the spare tyre well with the lifter the floor is slightly proud
Post #505304 15th Feb 2019 10:09pm
DrRob
Jorrocks wrote:
OK, the Grabber AT3 in 255/55R20 WILL fit in the wheel well, but only just! When the tyre fitter put it in, the floor was proud by half an inch and seemed to be obstructed by the sidewall, so I got him to deflate it which helped slightly. Anyway, once home I rattled the wheel around a bit and it settled in perfectly with the floor fitting flush. There looks to be enough clearance to allow at least 2.0 bar, but I’ll confirm in a day or two.
Did you get the 55 to fit ok in the wheel well with a bit more air than 2 bar? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #567211 16th Sep 2020 7:58am
Range Rover L322
Here's a good comparison
Post #567932 24th Sep 2020 4:57pm
DrRob
Look good. Did the 55 spare go into wheel well ok? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #567938 24th Sep 2020 7:28pm
DrRob
255 55 20 General Grabber AT3 being fitted next week.... Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #610642 27th Oct 2021 5:21pm
PeteT80
Had AT3’s fitted on mine last year. Can’t fault them.
Post #610651 27th Oct 2021 6:02pm
DrRob
What size? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #610660 27th Oct 2021 6:37pm
PeteT80
255/55/20. As mentioned before the spare is a tad snug, had to deflate to about 18psi to get it in.
Post #610666 27th Oct 2021 6:52pm
GraemeS
Australia
I have 255/60R19 GG AT3 on D4 rims ready to go on when my current tyres wear down enough. They have a little more sidewall height and a higher load rating than 255/55R20 GG AT3 yet have the same OD. They fit in the spare wheel well at full pressure although mine's left side plastic has been trimmed to fit 275/55R20.
Post #610692 27th Oct 2021 8:34pm
DrRob
Does the floor still sit flat on top? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #610716 28th Oct 2021 6:26am
PeteT80
Yes the floor will sit flat. Bit of a wrestle to get the wheel in though.
Post #610720 28th Oct 2021 7:04am
you dont have to struggle with a 55 in the spare.....use a space saver wheel or one of the original 50 profiles as a spare.... ... - .- -.
Post #610722 28th Oct 2021 7:08am
