![]() | Home > Technical (L322) > towing with L322 |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8082 ![]() ![]() ![]() |
Sorry - no idea what one of those is.
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
I suspect the RR has trailer nose weight maximum limits like every car. Recently I was towing a 4-wheel minidigger trailer with a 1.5 ton scissor lift in it. The air suspension could not raise the car if the trailer wasn't loaded in a balanced manner. Might be an issue with the suspension on my car(!) but if you know your trailer/caravan is heavy at the front, particularly if a two wheel van/trailer I would use a load balancer arrangement if available. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
IIRC the nose weight limit is 150kg - which is about as high as it gets.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8761 ![]() ![]() ![]() |
It is alistair, but I think that’s a UK limit, the towing hitch will take more and I think that there is different limits in different countries.
I checked my handbook (2008MY) and it says the trailer nose weight is 150Kg max for diesels and 140Kg max for petrol but that if necessary when towing a heavy trailer with run-on brakes it can be increased to a max of 250Kg as long as the overall GVW combined with the trailer nose weight does not exceed the maximum rear axle weight limit of just over 2000 Kg.
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 811 ![]() ![]() ![]() |
thanks guys, i will have to experiment RR 2005 4.4 petrol
