![]() | Home > Range Rover P38 > Bordeaux |
Huttopia Member Since: 26 Jun 2017 Location: Worcestershire Posts: 187 ![]() ![]() |
Mike, thank you, the brochure arrived yesterday, very kind of you.
Reached this milestone today, not bad for 17 years!
DavidL Member Since: 14 Nov 2013 Location: wiltshire Posts: 143 ![]() ![]() |
The grills fade as they dry out over the years. To get can idea of the original colour find the cheapest vegetable oil you have in the cupboard and gently rub it in. If doesn't last forever but it does improve things. If you're feeling brave you can also gently heat the plastic with a hairdryer as this also restores some of the colour. |
Thanks David L, I cleaned it all down and used some gtechniq product on it, which brought it bake to life. It doesn’t look brand new, but good enough.
Hi,
Security Agent Member Since: 24 Jul 2018 Location: Lincolnshire Posts: 1 ![]() ![]() ![]() |
I have the same problem. Also had difficulty opening rear tailgat sometimes. Lubricant on all moving lock parts and cleaned out the button and it seems to have cured itself for the past 2 weeks |
Alternator bearings started playing up so new alternator and belt fitted last week. I’ve managed to source a passenger door arm rest and peg surround. I’m still looking for a pair of loadcover stop hinges!
Taking the P38 out of storage at the weekend, looking forward to having the old girl back, and of course finding out what has decided to pack up!!
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
LRO seems to have quite a bias in favour of the P38. Love the interiors. Look great. Enough wood and leather to be posh. Enough plastic to wear very well. |
Got the P38 out of storage at the weekend, connected to a freshly charged battery and she started first time. I got all the normal ‘window not set’ warnings which cleared with the normal up and down a couple of times.
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1040 ![]() ![]() |
Recently put mine into storage after getting little use since getting the l322 after spending the last few years refurbing it...the list is to long but it still holds up being the 4.6 against my 4.4 m62.
I managed to track down a new old stock lower tailgate for a whopping £775 plus shipping plus vat, so will give that a miss and try to source a decent second hand unit. It will be prepped and painted so it doesn't matter what colour it is, just the condition. That inside lip is a properly poor piece of design, a real corrosion trap!
RickR Member Since: 16 Aug 2018 Location: Scunthorpe Posts: 8 ![]() ![]() ![]() |
Hello there, nice P38. Regarding your tailgate issue, there`s a breaker local to me might be able to help, not far from Lincoln. Amazon 4x4. phone no. 01673 863322. His name`s Dan. Ive used him int` past, reasonable prices (or at least used to be!) Good luck. |
Thanks Rick, I’ll follow up.
