![]() | Home > Technical (L322) > Fbh fuse |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
It’s this to reset it for pairing a remote, if that’s what you are after....
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 ![]() ![]() ![]() |
my remote is paired, i believe my fbh has failed to strat 3 times so now needs resetting
Ah right.... not sure then.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198 ![]() ![]() ![]() |
You have a PM.
my battery was disconnected for some time last friday whilst i was fitting my deployable side steps, so would i be wasting my time trying to pull a fuse for the fbh? Would the battery disconnection reset everything anywyas?
well this things deffo crazy, ive been playing with it in the cold lol, and at one point i got a whiff of diesel, had a loud click towards the rear of the car which was really odd?
Bat |
I just had a real quick look with a head torch on lol and before typically the heavens opened up and whilst i was disconnecting the battery last friday to fit my steps i remember seeing a loose electrical connection plug?
If you can stick up a pic when it's daylight, someone may be able to identify it. Particularly if you can find the other part it fits into and a quick description of its location also helps, as much as you can. Cheers
This little plug seems to have like a plastic spade blanking connection that it connects to, however i cannot remember if i did this on friday when i spotted the wire or if they are suppose to mate with each other?
I think BB Mike has beaten us to it. Cheers
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 ![]() ![]() ![]() |
Please tell me what this connector is for, is it anything to do with the FBH ?
Can't recall what the connector is for, but it could be the one for transportation which is disconnected prior to first sale.
Thanks for reply.
