![]() | Home > Maintenance & Mods (L322) > Urgent Help Needed! L322 mechanic needed |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
www.rrlondon.co.uk Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Unnecessary quote removed
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
Have you had the codes read, if so what are they ? What are the symptoms.
larrypool Member Since: 06 Jan 2019 Location: LONDON Posts: 3 ![]() ![]() ![]() |
The symptoms are the fuel pump is leaking and there is a lot of white smoke coming out from the exhaust. |
Not allowing me to PM |
Ah, a bit of injector cleaner won't help then. Unfortunately a high pressure fuel pump isn't cheap.
