Home > Maintenance & Mods (L322) > Urgent Help Needed! L322 mechanic needed
larrypool
United Kingdom 2005 Range Rover Vogue Td6 Causeway Grey
Hi all, new member here, please forgive me if I'm breaking any forum rules.
Can anyone recommend a decent reasonably priced mechanic around West London? I have a 2005 L322 TD6 and there is a mechanical problem with the high pressure fuel pump and the injectors. Unfortunately my mechanic has moved and l am getting some high quotes to fix this.
Post #507532 5th Mar 2019 9:56pm
DrRob
www.rrlondon.co.uk Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #507536 5th Mar 2019 10:27pm
Sandyt
Re: Urgent Help Needed! L322 mechanic needed
Unnecessary quote removed
i use the local garage in my village now they do an array of range rovers from the village as well as astons all sorts really pm me if you want their details they are in wraysbury near windsor
Post #507556 6th Mar 2019 12:35am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
Have you had the codes read, if so what are they ? What are the symptoms.
If you are getting quotes to replace a high pressure pump and injectors then the bill will be extortionate no matter who the mechanic is.
It could be simple fix though 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #507666 6th Mar 2019 8:30pm
larrypool
The symptoms are the fuel pump is leaking and there is a lot of white smoke coming out from the exhaust.
Post #507669 6th Mar 2019 8:43pm
larrypool
Not allowing me to PM
Post #507671 6th Mar 2019 8:47pm
Grofus
Ah, a bit of injector cleaner won't help then. Unfortunately a high pressure fuel pump isn't cheap.
But read this, https://www.landyzone.co.uk/land-rover/td6...ir.307483/
You can PM after 3 posts I think 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #507676 6th Mar 2019 9:02pm
