![]() | Home > In Car Electronics (L322) > Dash cam hardwired from rear fusebox |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
You may find enough of what you are looking for in the centre console above the rear view mirror |
Wrecker79 Member Since: 15 May 2014 Location: Reading Posts: 92 ![]() ![]() ![]() |
Hi There!
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1473 ![]() ![]() |
How easy is it to get the roof console off and the black cover for the windscreen rain sensor.
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
There are two screws when you open the sunglasses holder if your going that route don't forget an inline fuse? |
S4mRR Member Since: 07 Mar 2019 Location: London Posts: 5 ![]() ![]() ![]() |
Probably should ha e asked before I ran all the cable!! I have it all installed now, is there a fuse I can use? |
When I did mine a bought a piggyback fuse from Halfords and used the fuse from the cigarette lighter? |
Is this fuse in the glove box or fuse box in the boot? |
Fuse 4 -- rear Aircon
Glove Box, Easier to take the glove box off its only screws and light gives you access to feed the wire up airbag cover up the side of the window? |
Unnecessary quote removed
This thing is doing my head in! Tried the rear seat heaters fuse and when I cut the engine they go off but the camera stays on! Same as everything else I have tried.... |
Don't forget it's likely to stay live for 10 mins or more until the car 'goes to sleep' Current: 2011 FFRR Vogue SE 4.4 TDV8
