Home > In Car Electronics (L322) > Dash cam hardwired from rear fusebox
S4mRR
United Kingdom 2010 Range Rover Vogue TDV8 Barolo Black
Anyone know which fuse in the rear fuse box is switched with the ignition? Seemed easier to access than the one in the glove box... Car is a 2010 Vogue tdv8 Smile
Post #507774 7th Mar 2019 2:27pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
You may find enough of what you are looking for in the centre console above the rear view mirror Wink Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #507776 7th Mar 2019 2:32pm
Wrecker79
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi There!
I wired mine from the roof console.
The permanent live was from the interior light feed, and the switched one was from the sunroof.
There is plenty of spare space up there to coil the wire (to save cutting it should you want to eventually fit it to something else) and fuses from the dashcam, and it saves having to remove any trim.
The rear camera cable can then be simply tucked into the door seal rubber. 2017 - L405 SC - WOW! just WOW!
2014 - L405 4.4
2010 - L322 3.6 - Carried me 100,581 miles then broke big-time
There are 10 types of people in this world;
Those that understand binary,
and those that don't.
Post #507778 7th Mar 2019 2:33pm
Rob99
How easy is it to get the roof console off and the black cover for the windscreen rain sensor.
Mine don't seem to want to come off and I can't see where the fixings are. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #507781 7th Mar 2019 2:44pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
There are two screws when you open the sunglasses holder if your going that route don't forget an inline fuse?
Post #507784 7th Mar 2019 2:57pm
S4mRR
Probably should ha e asked before I ran all the cable!! I have it all installed now, is there a fuse I can use?
Post #507785 7th Mar 2019 2:58pm
Tinman
When I did mine a bought a piggyback fuse from Halfords and used the fuse from the cigarette lighter?
Post #507786 7th Mar 2019 3:03pm
S4mRR
Is this fuse in the glove box or fuse box in the boot?
Post #507791 7th Mar 2019 3:55pm
Bushy30
Fuse 4 -- rear Aircon
Fuse 7 -- rear climate seats
Fuse 13 -- Air suspension compressor
Fuse 14 -- Rear blower motor
Fuse 15 -- Rear screen wiper
Fuse 20 -- rear seat heaters
Not sure but would have thought all of the above would be switched ignition Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #507806 7th Mar 2019 4:27pm
Tinman
Glove Box, Easier to take the glove box off its only screws and light gives you access to feed the wire up airbag cover up the side of the window?
Post #507807 7th Mar 2019 4:27pm
S4mRR
Unnecessary quote removed
Hmmm fuse number 7 in mine is the amplifier... No good, also tried the suspension compressor and it cuts power once the car is running. My options are
1 audio amp
2 adaptive dynamics
3 parking aid, blind spot monitor rear view camera
4 rear air con
5 air suspension
6 electronic Park brake
7 audio amp
8 trailer
9 spare
10 spare
11 glove Compartment
12 spare
13 air suspension compressor
14 rear blower motor
15 rear screen wiper
16 aux heater
17
18 spares
19
20 rear seat heaters...
Will try 14 rear blower motor
Post #507850 7th Mar 2019 7:27pm
S4mRR
This thing is doing my head in! Tried the rear seat heaters fuse and when I cut the engine they go off but the camera stays on! Same as everything else I have tried....
Post #507935 8th Mar 2019 11:05am
Bushy30
Don't forget it's likely to stay live for 10 mins or more until the car 'goes to sleep' Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #507952 8th Mar 2019 12:47pm
