Home > Technical (L322) > Trans Failsafe ....I KNOW I KNOW but i need help
Nifty190
United Kingdom 2006 Range Rover Vogue SE Td6 Buckingham Blue
Ok so i know this could be a billion things but please please bare with me
RR L322 2006 TD6 222000k ( im trying for 500K)
gearbox replaced at 108k
New Batt
Gearbox (GM) fluid and filter changed at LR at 200k
Diag code GEAR 2 INCORRECT RATIO
im getting Trans Failsafe Prog when i boot it hard or try incline after say 10 miles, i can clear the limp mode if i turn off and wait for the fault to clear of the dials lcd
i also notice that the Temp sits at just above 1/4 just above blue as normal and the heaters are some what pants in the winter but when i get TFP the temp is always at half way, once cleared and i drive for a few miles it goes down to the 1/4 mark again until i boot it (kickdown) or try steep incline again then temp rises .....
i have read many many posts about TFS however none i have found have the temp thing going on... so i have read that on some models they can suffer with blocked rads (bottom 8 rows or something) also the oil cooler ???? this in my mind would, with the heater temp being so low in the winter could well be the issue or am i barking up the wrong tree ????
HEEELLLPPP
Post #508362 12th Mar 2019 12:07am
Of the billion things.... Wink
1. Temperature
This sounds like your thermostats are shot
Main thermostat
EGR thermostat
Best to replace both (as you will have the latter out to get to the former!)
2. TFS
Could be blocked radiator and oil cooler....
Again easier to do both at the same time
Could be a gearbox/solenoid issue
Most of 1 and 2 can be found in the wiki .
Post #508378 12th Mar 2019 9:05am
gavinn
Mine threw the same code, and it was the solenoids, if that helps
Post #508380 12th Mar 2019 9:25am
Nifty190
thanks guys
i can do the RADS and thermostats but how much was the solenoid replacement roughly ???
also it has EGR delete would that make any difference to the Thermostats etc ?
Post #508389 12th Mar 2019 10:24am
EGR blanking on a TD6 should have no impact
Look here or search the forum for solenoid / ideas
https://www.fullfatrr.com/forum/topic45035.html .
Post #508390 12th Mar 2019 10:32am
gavinn
Hi
My Mechatronic unit valves and Solenoids were done by Robbs Garage 0151 638 1384, they did it in a day or so , also had the metal gearbox sump fitted and a complete oil change, 6 Speed ZF box, cant remember how much it cost but it was money well spent , give them a call on 0151 638 1384.
Cheers
Post #508517 13th Mar 2019 6:01am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
2. TFS
I found this again in one of my posts.
Land Rover issued a Technical Service Bulletin in September 2007 for "High Engine Speeds and/or Transmission Shift Problems" which stated :
"The customer may experience high engine speeds and/or transmission shift problems after driving for 25 minutes or longer. There may also be the possibility of the transmission overheat message being displayed on the instrument cluster. High transmission fluid temperatures may be the cause of the problem"
In other words the transmission is selecting 'cooling strategy' mode as the bulk oil temperature has exceeded 140 deg. C.
The fault is caused by a partial blockage in the lower eight tubes of the (engine) radiator which supply coolant to the transmission oil cooler - supposedly caused by "depletion of the coolant corrosion inhibitor".
The bulletin states that it's not possible to clean out the partial blockage and that the radiator must be replaced.
LTB00080 - 15 Aug 2007
VIN Numbers 100042-175505
This is one of the forum threads
http://www.fullfatrr.com/forum/topic27376-15.html
http://www.fullfatrr.com/forum/topic2438.html
Post #508542 13th Mar 2019 10:57am
