![]() | Home > Technical (L322) > Trans Failsafe ....I KNOW I KNOW but i need help |
Of the billion things.... |
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 ![]() ![]() |
Mine threw the same code, and it was the solenoids, if that helps |
Nifty190 Member Since: 26 Dec 2017 Location: Buckinghamshire Posts: 23 ![]() ![]() ![]() |
thanks guys
EGR blanking on a TD6 should have no impact
Hi
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263 ![]() ![]() ![]() |
I found this again in one of my posts. Land Rover issued a Technical Service Bulletin in September 2007 for "High Engine Speeds and/or Transmission Shift Problems" which stated : "The customer may experience high engine speeds and/or transmission shift problems after driving for 25 minutes or longer. There may also be the possibility of the transmission overheat message being displayed on the instrument cluster. High transmission fluid temperatures may be the cause of the problem" In other words the transmission is selecting 'cooling strategy' mode as the bulk oil temperature has exceeded 140 deg. C. The fault is caused by a partial blockage in the lower eight tubes of the (engine) radiator which supply coolant to the transmission oil cooler - supposedly caused by "depletion of the coolant corrosion inhibitor". The bulletin states that it's not possible to clean out the partial blockage and that the radiator must be replaced. LTB00080 - 15 Aug 2007 VIN Numbers 100042-175505 This is one of the forum threads http://www.fullfatrr.com/forum/topic27376-15.html http://www.fullfatrr.com/forum/topic2438.html |
