![]() | Home > Maintenance & Mods (L322) > Improve braking on a RR 4.4 TDV8 313cv |
| Bluewater9118 Member Since: 07 Mar 2016 Location: Angerville Posts: 31
Hello
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
why do you think the current brakes arent working properly????? |
| SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 263
I must admit after 6 yrs of driving the 3.6, with Brembo brakes, I do find my 2012 does not stop, anywhere near as quickly.
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2771
Are the pads glazed? Mine seem to be very aggressive after towing my 2T van. |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
What pads are you running? Lots of NON OE pads do NOT work on the 6 pots... And as 322's & 405's get a little older, sent to indies that fit ECP specials unfortunately |
So what is the recommended choice guys? |
gonna_go_double_r answer
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Yes those are the ones.
Over £200 for brake pads!!
| Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102
I've just fitted the standard EBC's available from Island4x4 -- all good so far Current: 2011 FFRR Vogue SE 4.4 TDV8
I have TRW GDB1834 at the front and TRW GDB1824 at the rear. |
Craig you don't rate EBC's then?
No no sir... I don't rate Mintex, Textar and especially the Brembo crap ECP's sell as its all |
| dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724
I have yellow stuff on my fronts and they are overkill , greenstuff more than up to the job. Yellow stuff won't fade and under normal driving nor will green stuff. Maybe your pads or discs have an issue ? 2015 4.4 AB
