Home > Maintenance & Mods (L322) > Improve braking on a RR 4.4 TDV8 313cv
Bluewater9118
France 2011 Range Rover Vogue SE TDV8 Nara Bronze
Hello
Has anyone ever tried to improve the quality of braking on a range 4.4 TDV8 by putting:
- of perforated discs
- by changing the quality of the platelets (other than that sold by the concession)
- by ascending oversized stirrups and thus larger platelets
- see larger discs
What would you suggest?
Thank you for your advice and/or feedback
Michel
Post #508743 14th Mar 2019 8:06pm
GGDR
just change to EBC pads (they claim) can give you better stopping power, up to 30%
. Cheers, Greg
Post #508749 14th Mar 2019 8:34pm
why do you think the current brakes arent working properly?????
Post #508756 14th Mar 2019 9:26pm
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
I must admit after 6 yrs of driving the 3.6, with Brembo brakes, I do find my 2012 does not stop, anywhere near as quickly.
I am also looking at alternative discs and pads
Post #508766 14th Mar 2019 10:30pm
GraemeS
Are the pads glazed? Mine seem to be very aggressive after towing my 2T van.
Post #508776 14th Mar 2019 11:56pm
What pads are you running? Lots of NON OE pads do NOT work on the 6 pots... And as 322's & 405's get a little older, sent to indies that fit ECP specials unfortunately Rolling Eyes
Post #508778 15th Mar 2019 12:33am
SFM
So what is the recommended choice guys?
Post #508779 15th Mar 2019 12:52am
Bluewater9118
gonna_go_double_r answer
Under is that I found for EBC pads
https://www.ultraperformance.fr/plaquettes...313ch-l322
Post #508782 15th Mar 2019 6:47am
GGDR
Yes those are the ones.
Another member fitted these (yellow) which are the highest performance version.
I have the green ones (Greenstuff) fitted.
The brakes themselves are 6-pot brembos, can you get better? I guess if you go to race-style floating / cross-drilled etc. But you will need bigger wheels to fit anything bigger.
. Cheers, Greg
Post #508783 15th Mar 2019 8:20am
SFM
Over £200 for brake pads!!
Think I’ll put up with what I’ve got
Post #508785 15th Mar 2019 9:40am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
I've just fitted the standard EBC's available from Island4x4 -- all good so far Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #508794 15th Mar 2019 10:21am
GraemeS
I have TRW GDB1834 at the front and TRW GDB1824 at the rear.
Post #508796 15th Mar 2019 10:45am
GGDR
Craig you don't rate EBC's then?
. Cheers, Greg
Post #508871 15th Mar 2019 11:53pm
No no sir... I don't rate Mintex, Textar and especially the Brembo crap ECP's sell as its all Censored ! and do NOT work on the 6 pots! EBC have worked on every car i have tried them on thus far... Just not tried them on a RR yet sir Thumbs Up
Post #508873 16th Mar 2019 1:27am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I have yellow stuff on my fronts and they are overkill , greenstuff more than up to the job. Yellow stuff won't fade and under normal driving nor will green stuff. Maybe your pads or discs have an issue ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #508874 16th Mar 2019 1:42am
