Home > My Range Rover > range rover with problems |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 701 |
this thermostat is driving me daft TI 32 88
20th Mar 2019 3:09pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
You have done bloody well with only one pipe, that is your diff breather and tucks under your plastic coil cover
21st Mar 2019 12:23am |
21st Mar 2019 4:04am |
It was the first question i asked when i first got my fatty, I had the same pipe in the same place.
21st Mar 2019 10:16pm |
yes , it was the wiring, i haven't started the engine yet to check but i had not put the main 12v wire back on RR 2005 4.4 petrol
24th Mar 2019 6:40am |
Easily done, good job. |
24th Mar 2019 4:25pm |
the thermostat arrived today
10th Apr 2019 12:36pm |
That is about what i paid for mine and then didn't use it but used the 80 deg mod kit instead.
10th Apr 2019 8:32pm |
Well, at long last I have got it all together, almost,
22nd Apr 2019 10:42am |
Good effort, you are getting there.
22nd Apr 2019 7:01pm |
i forgot to say the "HDC inactive" comes up on the dash
23rd Apr 2019 2:12am |
Not quite 27 degrees here at the moment ..
23rd Apr 2019 9:13am |
i swapped over the cam shaft sensors, still the same.
23rd Apr 2019 11:18am |
Have a search of M62 and the POO11 code, quite a bit of info regarding the code after timing chain and guides, might give you something else to try after solenoids.
23rd Apr 2019 6:33pm |
