Home > Technical (L322) > Key fob and central locking |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34938 |
first step is to change the keyfob battery.. |
28th Mar 2019 3:53pm |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 |
Anyone have any tips with changing the battery before I wreck something?
29th Mar 2019 1:13am |
it shouldn't be..it slides out... |
29th Mar 2019 7:42am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
They charge through the ignition on an 07MY Stan... |
29th Mar 2019 8:00am |
Doesn't RRUK do key refurbishments?
29th Mar 2019 8:06am |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Battery definitely doesn’t ‘slide out’, you need to desolder the two pins from the battery on the circuit board. Get a repair kit or battery and you will see what to do. It’s not hard, just need a soldering iron with a small tip and a steady hand. |
29th Mar 2019 8:36am |
Check out nut job on YouTube, he did a video on repairing his key fob which included replacing the battery |
29th Mar 2019 8:38am |
so the batterys that charge via the ignition are soldered in, didnt know that....but, i assume that if the battery has gone past its recharge capacity then a new one is required.. |
29th Mar 2019 8:54am |
Thanks fellas much appreciated.
29th Mar 2019 12:25pm |
