Home > General > Have I bought a lemon?
Andy
I know Range Rovers are money pits and I ran a TD6 for 10 years which involved constantly doing something to it to keep it running.
I decided to get a newer one as I was getting tired of spending my time off fixing the TD6. I looked around for a decent TDV8 and found what I thought was a good one.
I’m now thinking I’ve made a mistake. Although it has relatively low mileage and full service history it hasn’t made it fault free
The fluttering noise I can hear now appears from research to be a leaking exhaust manifold. I dread to think what that will cost. It doesn’t look a DIY job.
I bought this car as I didn’t want to mess anymore I just wanted a reliable car that I could get in and drive with a smile on my face but it just seems like I’m back to square one again having to get the spanners out.
It also makes a loud diesel rattle on acceleration. My TD6 wasn’t this bad. That I’m told could be down to a dodgy remap that has simply advanced the timing. That needs confirming. I don’t recall the other 3 TDV8s I test drove being this audible.
I’m getting 20mpg average on a run.
It drives lovely but I’m on edge all the time thinking something’s about to go bang.
Should’ve stuck with the TD6- so disappointed. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #510378 31st Mar 2019 8:59am
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Thats poor MPG Andy. where abouts are you in Salop.
Post #510382 31st Mar 2019 10:30am
SlyBacon
United Kingdom 2007 Range Rover HSE TDV8 Rimini Red
Hi Andy,
I too am in a similar predicament as I too feel like I can't trust my 2007 Tdv8. I also have the fluttering noise when on light boost. This may not be down to the exhaust manifold, although it's very likely. It could be due to a split hose near the turbo which I think can be accessed through the wheel arch. I've ordered some new boost hoses for them and will fit next weekend will let you know if there is any difference.
James
Post #510383 31st Mar 2019 10:30am
Andy
Brian
Near Much Wenlock. We have a holiday home there. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #510386 31st Mar 2019 10:37am
Andy
James how much are the hoses and where from? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #510387 31st Mar 2019 10:46am
brian1951
Andy wrote:
Brian
It was just a thought you may want to compare it to another TDV8 im 8 miles the other side of shrewsbury 20 mins away.
Post #510389 31st Mar 2019 10:53am
Andy
Could do. I’ll let you know when we are back over that way. Thanks 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #510390 31st Mar 2019 10:56am
brian1951
No problem, you could drive mine and compare, drop me a PM.
Post #510391 31st Mar 2019 10:59am
ur20v
A Trap
Looks like loads of us FF idiots come from Shropshire... spent 40 yrs ‘growing up’ in Shrewsbury before Oz and now Spain. Must be the water.
James
Post #510400 31st Mar 2019 1:34pm
archermav
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
Likewise Andy, I'm just off junc 9 M6 if you need a comparison Thumbs Up
Post #510401 31st Mar 2019 1:35pm
Andy
Thanks. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #510412 31st Mar 2019 4:39pm
telly-addict
Scotland 2011 Range Rover Vogue TDV8 Stornoway Grey
Hey Andy, did you progress this at all?
Post #514188 4th May 2019 10:11am
Andy
Not yet. I did find out it had been remapped though. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #514326 5th May 2019 9:01am
telly-addict
Yeah that will probably accentuate it. Mine is needing changed (NS) but reading up on the job, I'm going to wait until I get my vehicle lift installed Rolling Eyes Cam
2011 TDV8 Vogue in Stornoway Grey
Post #514357 5th May 2019 12:54pm
Andy
I fitted two silicone top hoses a couple of weeks ago and I thought I’d sorted the restricted performance message and the mpg seemed to improve. Sadly, 5 days later it faulted again.
I can go days without a fault then it’ll go again. I have started using the Auto trip meter as the average fuel on A and B seemed to stick at 17. Now each trip I make is reset using the Auto and I’m seeing 24mpg around town so I’m not sure how accurate the A and B trip meters are.
The diesel rattle continues under load and I’m still trying to find the fluttering noise which is best described as a rattlesnake. I have recorded it and if I can work out how to upload it here I will. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #517441 4th Jun 2019 6:50pm
