Home > Technical (L322) > Engine don't start now |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
disconnect the seat power leave for 30 minutes letting everything power down, and then see if it starts.. |
1st Apr 2019 3:24pm |
Cheapscaff Member Since: 04 Mar 2019 Location: Uxbridge Posts: 31 |
Hi Stan thanks for your help. I did that and it's still not starting could it be I need to reset the fuel cut off valve I've not managed to find it yet,failing that maybe easy start spray case the fuel pump has died. If it starts then could be new pump.
1st Apr 2019 5:45pm |
Forgot to mention the steering is ok Now I notice when trying to start the key will spring back as when stoping the start process but the starter is still engaged. I have to turn the ignition off. I now wish I had disconnected the battery before starting the seat project. |
1st Apr 2019 6:00pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3195 |
If I understand you correctly, it sounds as if the starter pinion is sticking in the engaged position. If that is the case, it would mean removing the starter to ensure the pinion is free to recoil or, possibly, a new starter motor. John
1st Apr 2019 6:05pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
How is your battery? If it has run down below 12.5v it will play havoc with the electrical systems |
hi the battery is/was fully charged I'm hoping if I can sort out the non starting issue it might sort the starter out on start up. |
1st Apr 2019 6:24pm |
Hi all Can anyone pinpoint the location of the inertia cut out reset button. Tomorrow I'm going to check if I have a spark by removing a spark plug an coil. Also if I have fuel pressure at the shreader valve on the top of engine and power to fuel
1st Apr 2019 8:25pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Does thevengine crank but not fire or it won’t turn over at all? |
2nd Apr 2019 1:46am |
Hi thanks for your time. The engine cranks over fine it just don't fire up. I'm going out to pull it to bits now. |
2nd Apr 2019 9:56am |
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 |
If it's turning over but not catching, it could be lack of fuel. If there's nothing coming out of the schrader valve, have a look under the rear seats - you'll find the tank access hatches - the low pressure pump is in the tank on the right hand side so check for power there.
2nd Apr 2019 10:22am |
Hi thanks for your help. I have checked the pump fuse that's ok if I bypass the relay the pump works ok if I replace the relay the pump won't work I have put the heated seat relay (same numbers) in and it don't work. Is there a way to bench test a relay. I have removed the fuel pump unit from the tank already? Tia |
2nd Apr 2019 5:31pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
https://www.wikihow.com/Test-a-Relay .
2nd Apr 2019 5:52pm |
Have you tested the fuel pump relay in the connection for the seat relay (assuming they really are the same) - that'll tell you if it's the relay or the connection to it 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
2nd Apr 2019 7:34pm |
Hi yes I tried that and it was ok. Where I'm at now is I've checked the relays are working. I have found that when checking the power supply at the relay insert holes they are all correct with ignition on/ off im using hole 86 as ground.
2nd Apr 2019 8:14pm |
