Home > Maintenance & Mods (L322) > Deployable steps - fuse and control module locations |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
The earthing point is in the passenger footwell, not the drivers Current: 2011 FFRR Vogue SE 4.4 TDV8
2nd Apr 2019 6:09pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1136 |
I concur |
2nd Apr 2019 6:13pm |
the other way to operate the steps to open the tailgate? |
2nd Apr 2019 6:17pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 536 |
Yes, something I do know about but tailgate doesn't do it either. Mike - MPx
2nd Apr 2019 6:24pm |
If the age of the steps is the same as your car, then I would go for a new set and keep the old ones for spares? saves buying parts which will cost more in the long run. |
2nd Apr 2019 6:37pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16185 |
Bin um! Replace them with a new set as once they get to that state, they are a massive frustrating PITA!!! Lifes too short sir |
2nd Apr 2019 7:36pm |
Yes steps were a factory fit on mine so 2012 vintage. I agree - new steps and module on order... I just hope I'm up to fitting them (well getting the old ones off is the worry really), but I've got a few hundred to spend on an Indie if necessary before reaching MD levels of pain! Mike - MPx
2nd Apr 2019 11:45pm |
Buy your self a cheap set of pry off tools to help you get to any of the internal panels and some good penetrating oil for the bolts into the chassis, it's only 6 bolts each side to get them off. |
3rd Apr 2019 6:35am |
I'm hoping not to need the pry offs - I know I can get at the control Module and that's the only internal bit I'm renewing. Good point on the bolts - I'll start the daily Plus Gas soaking ritual in prep! Mike - MPx
3rd Apr 2019 10:01am |
You have 6 bolts per step, 4 in the sidesill area and 2 up into the floor... The 13mm headed bolts up into the floor are devils for snapping so yes, spray spray spray! Then when you get them moving, wind them in & out several times sir |
3rd Apr 2019 10:18am |
The 13mm bolts are the only ones that need to come all the way out the other 4, 11mm does not. |
3rd Apr 2019 12:54pm |
Well I'm now sorted and thought I should post how it went.
15th Apr 2019 2:39pm |
15th Apr 2019 2:53pm |
Glad you got them sorted |
15th Apr 2019 4:11pm |
