![]() | Home > Maintenance & Mods (L322) > Parcel Shelf Rattle ! |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 ![]() ![]() |
If you’ve put foam underneath and it still rattles is it moving slightly left and right, enough to make a noise?
cozzy Member Since: 15 Jan 2019 Location: Norfolk Posts: 76 ![]() ![]() ![]() |
Hi Steve ,
Check that the trim it attaches to is not prone to rattle - all fitment points. Basically sit in the boot and pull/push everything |
Hi DMRR, I have tried to wiggle jiggle, push and pull everything in that area........ lol .
I'll be at Snetterton week after next (19-21st trackside photographer), staying at the Premier Inn. Can possibly stick my spare (as in the one from my 2006!) in the boot for you - if you want to try a different one - at least that'll rule out the cover! Mines grey .... Land Rover Addict
Popeye Member Since: 15 Sep 2017 Location: Kent Posts: 27 ![]() ![]() ![]() |
I had this and it drove me mad. Short of one of my mates driving around with me in the boot looking out for the noise, I found out it was the upper tailgate. I adjusted the spacer nuts at each side and the noise disappeared.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8031 ![]() ![]() ![]() |
I had tape around the pins on mine - made them a little fatter and seemed to work for me |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
I had the same and eventually discovered that the tail gate latching mechanism, in the lower tail gate, was loose.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Hi Cozzy
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Had the same sort of rattle until about 5 mins ago |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
this is what I did, fome plus shrink tubing on the pins
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2700 ![]() ![]() ![]() |
Drove me mental. I had some self amalgamating tape which is used for waterproofing cable joints, worked a treat on the pins. I can have a look to see if I still have some. |
Just a quick update with regard to this rather annoying rattle from the shelf. I have checked the location spring clips, all are in place and look ok. I got hold of some heat shrink tubing to try on all of the shelf pins.......this has without doubt made an improvement on the rattle.
