Home > Maintenance & Mods (L322) > Parcel Shelf Rattle ! |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 284 |
If you’ve put foam underneath and it still rattles is it moving slightly left and right, enough to make a noise?
8th Apr 2019 12:41pm |
cozzy Member Since: 15 Jan 2019 Location: Norfolk Posts: 69 |
Hi Steve ,
8th Apr 2019 12:51pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Check that the trim it attaches to is not prone to rattle - all fitment points. Basically sit in the boot and pull/push everything Land Rover Addict
8th Apr 2019 12:55pm |
Hi DMRR, I have tried to wiggle jiggle, push and pull everything in that area........ lol .
8th Apr 2019 1:25pm |
I'll be at Snetterton week after next (19-21st trackside photographer), staying at the Premier Inn. Can possibly stick my spare (as in the one from my 2006!) in the boot for you - if you want to try a different one - at least that'll rule out the cover! Mines grey .... Land Rover Addict
8th Apr 2019 2:11pm |
Popeye Member Since: 15 Sep 2017 Location: Kent Posts: 27 |
I had this and it drove me mad. Short of one of my mates driving around with me in the boot looking out for the noise, I found out it was the upper tailgate. I adjusted the spacer nuts at each side and the noise disappeared.
8th Apr 2019 3:35pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7797 |
I had tape around the pins on mine - made them a little fatter and seemed to work for me |
8th Apr 2019 3:43pm |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 843 |
I had the same and eventually discovered that the tail gate latching mechanism, in the lower tail gate, was loose.
8th Apr 2019 3:54pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1194 |
Hi Cozzy
8th Apr 2019 4:36pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
Had the same sort of rattle until about 5 mins ago
8th Apr 2019 6:17pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
this is what I did, fome plus shrink tubing on the pins
8th Apr 2019 7:03pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
Drove me mental. I had some self amalgamating tape which is used for waterproofing cable joints, worked a treat on the pins. I can have a look to see if I still have some. |
8th Apr 2019 9:44pm |
Just a quick update with regard to this rather annoying rattle from the shelf. I have checked the location spring clips, all are in place and look ok. I got hold of some heat shrink tubing to try on all of the shelf pins.......this has without doubt made an improvement on the rattle.
11th Apr 2019 11:25am |
