Home > Technical (L322) > i'm making some progress with the fbh
dazza1983
So yesterday i changed my battery on the range as an idea for why my fbh wasnt firing up for parked heating but was firing up with a cold engine..
So tried it this morning the new battery in and it deffo fired up, I could hear the fuel pump pulse / click at the rear and the fbh sounded like it was properly burning.. It ran for somewhere between 15-20 mins but i was suprised to find the cabin wasnt warm...
However it did do this to the screen?
So made some progress but still not there 100% so any input please?? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #511413 9th Apr 2019 8:20am
rjff
Daz
This is going to Censored you off, but mine got that far with ice on the screen on the coldest morning so far this winter. Mr. Green And the cabin had the chill off but I have to admit did not seem "warm".
Seriously that's getting better if the FBH stys on for 20 minutes, that's the time for a diesel. Did you say above you changed or charged the battery?
One question I have, how did you check the charging voltage on the car. Was it with a voltmeter on the battery while standing alongside and the car ticking over and did you have any electrics other than the FBH on? Cheers
Richard
Gap IIDBT
Post #511430 9th Apr 2019 1:15pm
Further to our exchange via PM - other physcial issues worth investigating:
CHANGEOVER VALVE
The changeover valve is a normally open solenoid valve installed between the supply and return sides of the
heater coolant circuit. The changeover valve is located in the engine compartment on the engine bulkhead.
When de-energized, the changeover valve connects the heater coolant circuit to the engine coolant circuit.
When energized, the changeover valve isolates the heater coolant circuit from the engine coolant circuit.
The changeover valve is controlled by a power feed from the ATC module.
Circulation Pump
The circulation pump is installed at the coolant inlet to the FFBH unit to assist the coolant flow through the
FFBH unit and the heater assembly. The pump runs continuously while the FFBH unit is in standby or active
operating modes. While the FFBH unit is inactive, coolant flow is reliant on the engine coolant pump and the
auxiliary coolant pump. .
Post #511431 9th Apr 2019 1:17pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
This might seem a stupid question and if so many apologies but did you have the heating dials turned to max ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #511432 9th Apr 2019 1:19pm
dazza1983
rjff wrote:
Daz
I had my local car parts shop put a proper tester on it. It has to be set to the correct agm setting and the. It puts a load on the battery I believe.
You can get a print out of the amps the voltage the charge percentage and the health percentage. Mine was at 45% charged after going from Southampton to Birmingham last week and the amps were well down also. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #511433 9th Apr 2019 1:20pm
dazza1983
Dolph the heating dials are irreverent with parked heating my friend. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #511434 9th Apr 2019 1:20pm
dazza1983
CHANGEOVER VALVE
Circulation Pump
Hey buddy thabks for this.
So can I check the changeover valve without any dismantling of the inner wheel arches etc?
You have a pic bud? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #511435 9th Apr 2019 1:22pm
Much easier with the wheelarch off, but you can try.... .
Post #511452 9th Apr 2019 3:03pm
rjff
Daz, Joe
Not quite sure, but isn't the changeover valve on the engine compartment rear bulkhead. Taking the pollen filter assembly out might let you see it.
Can't do mine to look as off out and again tomorrow.
Daz
If you don't get a chance let me know and I'll have a look at mine Friday for you. Cheers
Richard
Gap IIDBT
Post #511468 9th Apr 2019 4:45pm
dazza1983
That would be great buddy. As I’m stuck at work all week and crazy busy Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #511470 9th Apr 2019 4:50pm
rjff
Might even be Thursday. You've kindly given me a reason to get out of SWMBO to do list Very Happy Cheers
Richard
Gap IIDBT
Post #511471 9th Apr 2019 4:54pm
Agreed, but as it is "inline" with the FBH pipework, got to be easier to gain full access .
Post #511477 9th Apr 2019 5:17pm
dolph34
I could have sworn mine needs the dials on max to get the heat. If im wrong then i will stand corrected Thumbs Up i will conduct a test over the next two days. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #511522 9th Apr 2019 10:42pm
@ dolph34
no mention in RAVE or the 2007-10 manuals about needing to set the heat to max
FBH activity/ FBH park heating is determined by the external temperature / coolant temperature as monitored by the car .
Post #511527 10th Apr 2019 12:19am
p38arover
Australia
That's not very nice of them! Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #511562 10th Apr 2019 12:53pm
