Home > Technical (L322) > i'm making some progress with the fbh
dazza1983
Big Cry
LOL, its because the fbh will heat the coolant and then just flow it through the heater matrix so you cant control the temp it will just be watever the burner temp gets too i guess minus whatever is lost between the burner and the heater matrix...
So im wondering if mine is actually working now?? I guess i need to sit in the car and turn it on and physically feel what temp air is being blown,
But i ran it this morning and it burnt for 20 mins and when i got in the cabin the chill was gone but i wouldnt say it waS WARM, Am i expecting too much or should it be Noticeably warm in there? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #511566 10th Apr 2019 1:37pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Both my TDV8's are toasty warm and there's no ice on the screens (when icy) Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #511569 10th Apr 2019 2:18pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
When mines dials are turned to max ( Rolling with laughter) mine is toasty too Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #511571 10th Apr 2019 2:45pm
dazza1983
I don’t want to jinx anything but I think it might be starting to work Very Happy
Only thing I have to figure out now is how warm it should be in the cabin?
The heater is deffo running every time I hit the key fob now. And it runs for 20 mins or so I’ve used it every morning since new battery on Monday and it seems to be feeling warmer in the cabin each time.
This morning in Southampton it was 2 degrees so put the heater on at 7:40.
By 7:55 I got in the car and it wasn’t toasty warm but there was a tiny hint of residual warm air floating around. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #511653 11th Apr 2019 9:05am
DMRR
It won't be warm after 6 minutes! After 15 minutes you'll get a proper flow of heat - if you are really really brave run it twice Wink Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #511660 11th Apr 2019 9:47am
dazza1983
Sorry I just edited it
It was 7:40 - 7:55 Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #511665 11th Apr 2019 10:08am
DMRR
Where is the dial set for the centre vents - set in the middle (so you can see blue/red on both sides)? Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #511669 11th Apr 2019 10:31am
dazza1983
Set to red buddy. Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #511670 11th Apr 2019 10:34am
rjff
Daz
Looked at the possibility of getting to the changeover valve by removing the pollen filter assmebly and it does look as if the wheel arch liner needs to come out. Can't see the valve assembly i'm afraid to say Cheers
Richard
Gap IIDBT
Post #511718 11th Apr 2019 6:06pm
dazza1983
AH was always going to be the way lol,
Anyways i think it might be working lol, i turned it on this morning and after 20 mins sat in the car as i opened the doors the blowers turned off , when i shut the door they started up again and the air was luke warm? Not cool .. but not hot??
Am i expecting too much heat?
Also im guessing as soon as ive opened the tailgate and then the door you probably loose loads of heat instantly?
Peoples thoughts? Regards
Daz
sumatra black
previous cars
e46 m3
e53 x5
Post #511772 12th Apr 2019 9:01am
rjff
Get in and out quicker Razz
Sounds as if you're getting there Daz. Mine wasn't as toasty as some say during the coldest days, and I have to admit to not using the car too many early mornings as I don't commute anymore Thumbs Up
Come next winter I'll have to see what the FBH does about early doors heating and maybe run some temp sensors outside and inside. I'll stop there, beginning to sound a bit too Censored retentive Cheers
Richard
Gap IIDBT
Post #511807 12th Apr 2019 11:30am
