![]() | Home > Technical (L322) > Selecting Neutral and Towing |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
On ours, (11MY) take out the cupholders and there's a tag you can pull to select neutral (I think).
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
Thanks for that. I’ll have a look 2007 3.6 TDV8 |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2695 ![]() ![]() |
The 6-speed lever mechanism has a white plastic tab at the right rear corner of the mechanism which when operated (lifted IIRC but possibly pressed) unlocks the lever to alow it to be pulled into neutral. I don't know how the tab is accessed on the L322 but on D3s & D4s the cup-holders, which are located behind the lever mechanism, are lifted out. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8751 ![]() ![]() ![]() |
