Home > Technical (L322) > Selecting Neutral and Towing
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Just out of interest, is there a way to move from Park to Neutral without needing the key in the ignition?
I’ve read somewhere about “fuse 11” being utilised for shifting the transfer box into neutral, or maybe this isn’t for the L322.
Anyhoos, after recently being immobile due to a steering lock issue, I was wondering how to get towed? 2007 3.6 TDV8
Post #511696 11th Apr 2019 3:28pm
rjff
On ours, (11MY) take out the cupholders and there's a tag you can pull to select neutral (I think).
Maybe similar on yours. Cheers
Richard
Gap IIDBT
Post #511822 12th Apr 2019 2:30pm
cheezels
Thanks for that. I’ll have a look 2007 3.6 TDV8
Post #511900 13th Apr 2019 1:05am
GraemeS
Australia
The 6-speed lever mechanism has a white plastic tab at the right rear corner of the mechanism which when operated (lifted IIRC but possibly pressed) unlocks the lever to alow it to be pulled into neutral. I don't know how the tab is accessed on the L322 but on D3s & D4s the cup-holders, which are located behind the lever mechanism, are lifted out.
Post #511902 13th Apr 2019 3:41am
Under there.😃👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #511946 13th Apr 2019 4:20pm
