![]() | Home > Technical (L322) > 2012 TDV8 Air Con issues, looking for help and advice |
RCV ? .
TDV8_Tommy Member Since: 20 Feb 2019 Location: Pinoso, Valencia Posts: 434 ![]() ![]() ![]() |
Refrigerant Control Valve.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7987 ![]() ![]() ![]() |
Yeah, it’s that valve. Mine takes a while to blow cold sometimes....
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
Obvious things first, but check the control wheel on the centre vents is set to blue... There is nothing that can't be fixed with a hammer😜😜
Totally agree, northernmonkeyjones, I did that 😁
Unlikely, my obd tool tells me nothing most of the time..... There is nothing that can't be fixed with a hammer😜😜
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
Does your AC shop check everything works before gassing? Here in the UK they have to as its illegal to fill an untested system as it could leak into the environment!
