![]() | Home > Technical (L322) > Intermittently stuck in Park |
Skeletor Member Since: 06 Apr 2019 Location: Cornwall Posts: 18 ![]() ![]() ![]() |
Seem to have an intermittent issue normally first thing in the morning, can’t get the selector out of park, pressing the brake you can hear a little click by the stick but still won’t move, try it a couple times either works or turn the engine off and back on it will go. What stops the gearbox going out of park?
Have a check on your gear selector rod alongside the gearbox. These can seize, come loose etc. If forced, rod can bend as well! .
It will move and then be fine all day, then intermittently it just won’t budge. Seems like there is something electronic stopping it moving |
