![]() | Home > Technical (L322) > Engine system fault |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
can you fill your car profile in so we know what model/engine you have.. |
| Freedriver Member Since: 04 Apr 2019 Location: Darwin Posts: 13
Done.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
3.6 tdv8
Thank you . I have removed the top hoses and they seem good and pretty new looking. I am currently going right through all wiring connectors . I did find one connector to the driver side egr valve seemed to be not fully connected so I pushed that one together, reconnect the battery and started it up. No engine fault but chugging slightly. Kind of feels like an injector or 2 not firing . |
Search up split manifold in the search box.
Well, I have today removed the inlet manifolds, found one hose clamp that had seized up and was not tight and I thought I had found the problem, new hose clamp. But after checking every connection and putting it all back together she is running rough as guts.
| Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247
Oh yes, don't get me started on fuel pumps....
Thanks tugger , that has given me a few things to check |
Pretty useful video from the guys at PowerfulUK on checking the fuel pump
Thanks for that , its a bit different to the 3.6 TD but i get the general idea. |
Ok so today I changed the fuel filter and confirmed I have fuel flow at the filter. I also accessed the top of the fuel tank and listed to the fuel pump. It’s much quieter than the one in my discovery 2 but seems like it is operating correctly. I then tried to start her up, yes it started but running extremely rough with a lot of blue/grey smoke . I am now begging to think I have a serious problem like turbo failure or injection pump . Thanks to Australia post and Easter holiday my iid tool hasn’t arrived so I am stabbing in the dark a bit . The few hundred km I drove it were fantastic though so I better be able to fix it
| dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724
When one of my turbos snapped an impeller shaft there was a smoke screen behind me that 007 would have been proud of |
| ur20v Member Since: 19 Feb 2019 Location: None Posts: 634
turbo issues don’t normally cause rough running, lack of performance from seizing vanes or shaft and or oil smoke and leaks.
Hi again, well here i am onboard my flight back to Darwin having left my L322 at my brothers place. I still haven't figured out what went wrong with the motor so to recap here is the story so far.
| All times are GMT |
