![]() | Home > Technical (L322) > L322 2011 4.4 TDV8 Suspension / compressor fault |
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 177 ![]() ![]() ![]() |
You are in luck (sort of) my post 'suspension issues after towing' describes the exact symptoms you have
Baz1975 Member Since: 26 Nov 2013 Location: Newtownabbey Posts: 55 ![]() ![]() ![]() |
Thanks, but my compressor gets up to pressure & cuts out as required, it doesn’t kick in again, therefore I’m under the understanding that the pressure is fine.
Exhaust on the compressor not opening to allow it to start up again? Assuming it works like an unloading valve on a static compressor
Do you know the pressure is fine - I. E have you checked on diagnostics? |
I don’t have a IID tool, hoping my sons mate will call over Easter and connect his up.
gavinn Member Since: 11 Apr 2017 Location: west midlands Posts: 60 ![]() ![]() |
Had the same sort of issue, there is a little screw in brass exhaust filter/silencer on the compressor that gets clogged, you can replace it , or do as i did , unscrew and throw away to replace at a later date (that was 2 years ago) , you will get a louder PSSSHHHH when the compressor exhausts but apart from that all good ! |
Thanks, but that is brand new along with the compressor. Current: 2015 4.4 SDV8 Autobiography
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1523 ![]() ![]() |
Might be worth looking at the plastic pipes and the big tubular reservoir on the drivers side to check for leaks, could even be that the bags are still fine, but the system from them back is leaking somewhere?
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Did you replace the compressor with the same make? if not I believe it needs to be programmed? |
I got a valve block if you need one - the one closest to the compressor (i.e. IN the boot) Land Rover Addict
Compressor changed like for like. Current: 2015 4.4 SDV8 Autobiography
UPDATE:
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4337 ![]() ![]() ![]() |
Might need the exhaust valve brass filter thingy bored out with a drill. Common issue.
