Home > Maintenance & Mods (L322) > New Wipers
New Wipers
Recently fitted new windscreen wipers to the car and after two weeks use they sound as if they have been on for about a year
After first sweep up and down they sound as if the actual metal parts of the wipers are scraping over the windscreen PITA
Post #51253 21st Feb 2011 9:44pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Mick, all last week and this weekend I've had wiper blades doing the same thing, I wonder it is the cold weather causing the rubbers to go hard? Have you tied warming them a bit with the front screen heater? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #51266 21st Feb 2011 10:52pm
Mick I bought a new set for mine this time last year and they were REALLY noisy the whole time, any weather, especially on the switch in direction.
When it was last in at the dealers before xmas I did something I don't normally do and just told them to replace them, even though I knew it would cost top whack.
The result? Silence................ Cool
Maybe they tweak the angles at the same time or maybe some wipers are just born Crap. For the sake of£30, get some new ones and see if its the same issue. Discovery 4 HSE
1993 90 Tdi
Post #51272 21st Feb 2011 11:15pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I'm stuck away in Dublin.
once I get back I'll take some measurements and pictures of my frameless conversion.
result: silence and £15/set wipers.
I'm also going to capture the wiper 'adjustments' in pictures although the main thing to remember is that for an expensive car the wiper arms are sh**. f'kin Mini One has much better quality arms than the cheapo made from the foil of a KitKat wrapper Friday afternoon sh*t that we're 'treated' to.
Still want to fashion some proper arms from actual metal with frameless facility easily.
Rant over... They're easy (ish) to adjust and as soon as I get out of this over priced dump I'll document it via the proper channels... Thumbs Up
Post #51282 22nd Feb 2011 12:07am
The ones i am talking about Adam are new bought them just over two weeks back from an LR Dealership ...... Rolling Eyes
Tim , have also tried your suggestion too ......... Thumbs Up
Post #51309 22nd Feb 2011 9:34am
Mick, just because they are new doesn't mean they are ok. My new ones were rubbish too, except I was daft enough to put up with them for a year. Discovery 4 HSE
1993 90 Tdi
Post #51310 22nd Feb 2011 9:42am
Stephen.125
Another reason I changed/sorted mine was that the metal actually WAS catching due to incorrect wiper angle scratched screen wasn't good...
However getting a brand new one fitted under warranty due to a non-working strip of the heating elements was great.
Didn't realise how pitted/scratched the screen was!!
You can adjust/tweak the angle in a couple of ways. first off unclip the plastic cap on the wiper and undo the nut (16mm spanner IIRC). You'll see the horizontal striations arranged in a curve which allow you to tilt the wiper until it's right.
The back of the wiper arm should be parallel to the screen. You can lay a straight edge on the arm to sight the angle more easily.
Probably while you've got the wiper arm off it's a good chance to clean the galvanic corrosion (white cr*p) off the alloy section of the wiper to allow the grooves to mate properly and also check the arm mechanism is clean and lubed up to it moves freely to collow the contours of the screen.
The other less elegant way is to grab the wiper assembly and bend the whole arm. (as I said above they are cheap and nasty) but for me this give less control over the angle and the only reason to try this approach is that someone else has beaten you to it and the wiper arm is no longer coplanar along it's whole final section.
I'll post pics at the weekend. and also how to adjust the stroke of the wipers.
Post #51316 22nd Feb 2011 9:57am
Only two months back the dealership re-aligned the wiper arms ......
Maybe the wipers are okay just need a new windscreen .................. Laughing Laughing Laughing
Post #51332 22nd Feb 2011 12:00pm
its possible that these wipers have been on display for a while and have gone 'hard' due to the heat in the showroom...i'd take them back and get a new set. ... - .- -.
Post #51333 22nd Feb 2011 12:04pm
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
"once I get back I'll take some measurements and pictures of my frameless conversion."
Would like more info on above.
I bought orig LR wipers and even had specialist fit them which is unlike me and after couple of days as rubbish as before.
Bought some aero wipers so just need to know how to convert!
Post #51392 22nd Feb 2011 7:11pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Mick, I had a problem with my last RR that actually had a scuff mark on the windscreen. I replaced them myself 1st with a bosch set, only to get noise and judder a week later.
Took it into two Land rover dealers and the second one fitted a new set of wipers. They said they were a softer compound to stop judder and worked fine from then on? My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #51412 22nd Feb 2011 8:43pm
T24RES
I'd be interested to know how to level the blades, i requested mine be alligned to the portion of the window where the elements are. They managed the drivers side and not the passenger side.
 Ian
Post #51567 23rd Feb 2011 3:05pm
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
i've not checked my car but there should be 'registration' marks on the windscreen glass (there are on jeeps Smile ) for alignment
Post #51570 23rd Feb 2011 3:15pm
http://www.fullfatrr.com/forum/topic4134.html?highlight=wipers
Post #51573 23rd Feb 2011 3:20pm
can you not take the wiper off the spline and re-position it... ... - .- -.
Post #51574 23rd Feb 2011 3:20pm
