Home > Maintenance & Mods (L322) > Bottle Jack or Trolley Jack?
WB
Trying to decide between the Sprinter bottle jack and a trolley jack. Either way I'll also get some Axel stands but not sure whether to go for the convenience of the smaller bottle jack or a sturdy trolley jack like the one below.
Anyone who has both or used both on their L322 that can share any thoughts?
https://www.sgs-engineering.com/tj3x-jsr-3...xle-stands
Many thanks
Post #512743 21st Apr 2019 4:41pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
The sprinter bottle jack is used by folk who dont trust the standard scissor jack at the roadside for an emergency wheel change. If you are after a jack to raise the car to work on then a trolley jack and axle stands is the way to go.
You need to decide what it willbe used for Thumbs Up 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #512745 21st Apr 2019 4:59pm
WB
Thanks for the advice.
One thing I'm not clear on is how much height needs to be achieved to get a wheel off the ground. I see the bottle jack has 570mm max height but the trolley jacks are around 465mm and I'm not sure if this is sufficient?
Many thanks
Post #512761 21st Apr 2019 6:28pm
I just bought this jack from SGS and used out for the first time today to swap to my summer wheels / tyres - it did the job very well Thumbs Up
However, I have an L405 with deployable steps, so have a much lower jacking point than the L322 - my Sprinter jack is too tall to even fit between the jacking point & the ground.
As above though, a trolley jack is much better at home, but you don't want to be transporting it. A bottle jack can be stored in the car, but not quite as easy to use....
I don't know how much height you need, but I'd use the factory jack & measure it for myself Thumbs Up
Post #512772 21st Apr 2019 7:46pm
DrRob
Wot he said đŸ‘† Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #512775 21st Apr 2019 7:48pm
DrRob
I lift it under the suspension with a trolley jack or a Disco 2 red bottle jack with a U shaped saddle.
Only need to lift it a few inches to change a wheel Thumbs Up
Much safer than lifting via sills Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #512776 21st Apr 2019 7:50pm
WB
Thanks all.
DrRob that’s an interesting idea - do you position the jack under the suspension arm? My only worry would be if that’s ok on the suspension air bag?
Post #512790 21st Apr 2019 10:53pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
with a jack under the suspension arm your fine for wheel changes - as said it only needs lifting a couple if inches.
yiu won't get a bottle jack under there though as it's so low. very easy with even cheap trolley jack. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #512799 22nd Apr 2019 9:12am
nino_nino
WB,
mine is from Disco td5
front
back
 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #512801 22nd Apr 2019 9:32am
Pawl
Nino_nino, thanks for those photos, I'd forgotten how short the double piston Discovery 2 jack is!
Last time I took it out of the box at the front of our Disco was quite a few years ago.
Maybe I should put it in the RR to replace the pathetic scissor jack Laughing Paul,
Post #512802 22nd Apr 2019 10:41am
DrRob
Those red jacks are perfect for changing a wheel and much safer than the scissor jack.... Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #512815 22nd Apr 2019 2:04pm
Grofus
Tyre fitters, and me, never use jacking points. Always under a suspension arm or subframe. A lot less lift needed so much more stable.
Even with a scissor jack , use a block of wood under the bottom mount for better load spread and lift away.
Much safer. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #512816 22nd Apr 2019 2:08pm
WB
Thanks guys, think I'm going to go with one of the Disco jacks for now and maybe invest in a trolley jack later.
Do you lift while the car is in regular, high or access mode? I'm assuming regular but better to ask.
Post #512859 22nd Apr 2019 10:04pm
GGDR
+1 for the sprinter jack.
. Cheers, Greg
Post #512862 22nd Apr 2019 10:53pm
nino_nino
WB, in the normal height if you are lifting just wheels and offroad height if lifting using jacking points. I use piece of 4"x4" under jack when lifting using jacking points. everything fits nicely in the storage bin in the beck.
2000 Disco. TD5
1975 series III
Post #512886 23rd Apr 2019 9:23am
