Home > Technical (L405) > Service Menu
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Service Menu
Looking for clues here. All I want to do is check the oil, but to do that I have to access the service menu and despite following the handbook instructions I can’t access it. It says press start button without touching brake pedal, but all that happens is I get a message saying press brake to start!! No sign of a service menu.....
Anyway, what’s wrong with a good old fashioned dipstick?!
Cheers
Andy
Post #512830 22nd Apr 2019 4:09pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
If it had a dipstick they could not charge you a fortune when it failed.
As with all things digital you have to keep repeat pressing
Press the OK buton on the steering wheel to clear, then press menu, then scroll down.
By the way the engine has to be warm, which is a tad unhelpfull as you cant check the engine has enough oil untill you have run it without enough oil. letters not necessarily in the right order
Post #512832 22nd Apr 2019 4:20pm
DrRob
You can check level when cold. Search on here for the long subject thread Thumbs Up
It requires bonnet open and a different combo of buttons... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #512839 22nd Apr 2019 6:05pm
Andy S
Thanks Dr Rob. Is there a link to the long thread? A search on “Checking oil” didn’t bring anything obvious up.
Thanks
Post #512842 22nd Apr 2019 6:16pm
This one ?
https://www.fullfatrr.com/forum/topic46960.html
or this ?
https://www.fullfatrr.com/forum/topic48156.html
Post #512846 22nd Apr 2019 6:55pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #512847 22nd Apr 2019 6:57pm
Andy S
Thanks all. A dipstick would be so much easier....
Post #512848 22nd Apr 2019 7:15pm
DrRob
Don’t top it up too much when cold or it will overfill Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #512857 22nd Apr 2019 8:49pm
fin
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
I’ll be trying this later. I wasn’t aware they didn’t have one, if it’s low does it warn you?
Post #512946 23rd Apr 2019 3:52pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
Assuming no malfunctions - Yes it warns you if the oil level is too low.
Post #513127 25th Apr 2019 9:32am
